hey i have a '90 ranger xlt, two wheel drive, automatic that i recently purchased off a friend for $200. i thought it was a great deal, however there are problems with the transmission, it wont engage into 1st in OD. i can drive up to 80km/h in D and switch over to OD and it works fine, and i can engage into 1st in D. is it worth rebuilding or replacing? also it leaks a few drops of oil everyday, i dont know if the two are at all related, but thought i would just add that in.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
It's 1200 to repair. Son's 89 did the same thing. Find a reliable tranny shop(good luck) and get an estimate and then shop it around other shops. Make sure the estimate is actual and not something that will double upon completion. Everything in it plus labor is 1200. Get it done before overdrive completely goes out.
Reason: spelling
I have never owned an automatic vehicle and i dont know much about them but it isnt really necessary to drive in first gear OD, is it? wouldnt your mileage and performance suffer a bit?
