Aerostar Ford Aerostar
Parking Brake Failure
Old May 11, 2005 | 11:15 PM
Plexter's Avatar
Plexter
Exclamation Parking Brake Failure
Pulled up on the handle of my 95 Aerostar's parking brake, felt a pop then handle went vertical. Checked inside the housing and everything seems hooked up ok, but the wheel which rotates as the handle is pulled doesn't rotate with the cable. Thinking of geting a replacement handle from the local bone yard. What do you think?
Old May 11, 2005 | 11:19 PM
93nighthawk's Avatar
93nighthawk
Did you check the linkage underneath from the brake to the rear wheels? One of the lines could have snaped or there is a part about half way to the rear wheels that tends to rust where the one line splits into to. Once you are sure about the part, go to the junkyard and start hunting for a good one. Dealer only item.
cyclone-429
Dec 9, 2013 11:38 AM
TDELONG83
Jul 1, 2010 07:19 PM
neumannfamily
Apr 12, 2009 10:11 PM
gangstakr
Jun 25, 2006 09:30 AM
MatthewB
Feb 5, 2002 09:23 AM
