problems with hesatation.
Old Jun 21, 2005 | 03:28 AM
OrdoDraconis's Avatar
OrdoDraconis
Old Jun 21, 2005 | 11:04 AM
IceWagon's Avatar
IceWagon
Have you tested your EGR valve? Make sure EGR valve isn't sticking, broken or leaking.
One simple test would be to disconnect the vacuum hose to the EGR and plug it. EGR Valve should close all the way. Look for any leaks problems. Test drive and see if the problem changes any.
Old Jun 21, 2005 | 07:49 PM
OrdoDraconis
did this same problem no differnt i also decided to check the igntion module i replaced it with a new one thank god for discont from my work otherwise it would have been 59 bucks i got it for 28.90 but same problem no changes
Old Jun 21, 2005 | 08:34 PM
OrdoDraconis
i was wondering if it could be the FPR is there any to test it im gonna have my uncle hook up the fuel pressure tester tommorow and we will try that im thinking i might go out and replace all the vaccum line just to make sure that that aint the problem i found out why my brakes werent working right though te vaccum line from the master cylinder wasnt hooke up i felt stupid about that. my uncle also decide to try spaing ether by the exhaust manifold and intake to see if the idle change that would mean there was a hole but nope not there either.
Old Jun 21, 2005 | 08:35 PM
OrdoDraconis
also were the egr isnt hooked up to my exhast any more could that cause another problem cause i was thinking about remoing it completely and place a steel plate in its place wit a new gasket and some rtv. my exhaust smells realy rich and there is some buffering and bad idle.
Old Jun 21, 2005 | 08:36 PM
OrdoDraconis
dose the cranckcase brether need vaccum to it?
Old Jun 23, 2005 | 07:45 PM
OrdoDraconis
i did a fuel pressure test im sitting at 10 psi im not sure where to go from here i can get a new electric pump for 80 bucks should i try that.
fp_5
Oct 24, 2021 12:07 AM
Jymmm
21
Apr 3, 2019 12:52 AM
cjdguy
1997 - 2003 F150
Oct 30, 2012 09:49 AM
workinstiff
1983 - 2012 Ranger & B-Series
Jun 22, 2011 12:40 PM
