problems with hesatation.
Old May 11, 2005 | 09:26 PM
OrdoDraconis's Avatar
OrdoDraconis
Cool problems with hesatation.
when im diving down the road all of the sudden my truck begins to bog down and not want to accelarte until i hammer the gas then it takes off, i changed the fuel filter, plugs, wires and it has a custome air intake a y peice of exhaust pipe welded into a 3 inch pipe with a cone filter held on by vulcan hosing and hose clamps its seams alright it makes a a nice sucking sound when you hammer the gas as for the crankcase breather i use an aftermarket cone one. well now recently my truck either wont start or it starts and just die a block or two away from my house, i was wondering is the a possiblity that the fuel lines are plugged, this truck sit for a year or two before i did any thing for it and do you think i should put something in the tank to clean it out i did use a can of seafoam in the tank but there might be crap in the tank from were it sat so long im realy unsure and frankly im getting very pissy cause i cant figure out whats wrong, it seems like when i fix something another part goes out on me.
one more ? when you press on the little valve to check fuel pressure should fuel come out and do you have to have the vehicle running when you are testing this pressure
oh dose anyone know were i can find any oild dipstick tube?
SPECS: 1987 F-150 2wd 4 speed manual dual tanks 4.9L 300 EFI
chevy trail blazer exhaust sounds great from a 2000
Old May 18, 2005 | 01:59 AM
OrdoDraconis
Exclamation
well i checked the fuel pressure with a gauge, the gauge reads 0 fuel pressure so i decided to ask a professional about it he did mention something about a fuel cutoff switch or button but he said he did not know exactly where it is located any ideas? so if some one can tell me where its at that would be great oh and can some one point me to a website that has exploded views of under the hood and dash that would be great.
Old May 18, 2005 | 08:33 PM
jrscars's Avatar
jrscars
your fuel cuttoff switch is near the steering column on the firewall, inside the truck. press the white button on top to reset it.
looks like we share identical trucks.
Old May 19, 2005 | 01:46 AM
OrdoDraconis
Well Thats Not It Hmmm Any Other Guesses Any One?
Old May 19, 2005 | 03:13 AM
OrdoDraconis
Unhappy
WELL I HAVE DONE GIVE UP ON ME TRYING TO SOLVE THE PROBLEM I WAS GONNA HOOK IT UP TO A COMPUTER TO CHECK CODES THEN I REMEBERED THAT IF I DO THAT IT WILL GO CRAZY CAUSE ALL THE EMISSIONS CONTROL CRAP HAS BEEN REMOVED ECCEPT ERG SO IM THINKING IT MY HIGH PRESSURE FUEL PUMP BY MY FUEL FILTER CAUSE I GOT 0 FUEL PRESSURE FROM BOTH TANKS I REPALCE THE SELECTOR SWITCH TO SEE IF THAT WAS IT NOPE, ITS GOING TO cLEGGS SERVICE AND REPAIR TOMMOROW HERE IN MY HOME TOWN OF BURLEY IDAHO THATS MY UNCLE HES THE MAN WHEN IT COMES TO FORDS HE HAS FOUR TRUCKS ALL WITH 300 INLINE SIXES IN THEM I ALSO CHECK THAT CUTOFF SWITCH THAT SEEM INTACTED STILL OH I DID FIND AN OIL DIPSTICK TUBE FOR 15 BUCKS AT A SALVAGE YARD DOSE ANY ONE KNOW IF THE DIPSTICK TUBE FROM A CARBED MODEL IS THE SAME AS A EFI MODEL?
Old May 20, 2005 | 01:33 AM
OrdoDraconis
Well I Figured It Out Yesterday Come To Find Out The Relay For My Fuel Pump Was Full Of Water As Well It Shorted Out My Fuel Cutoff Switch Causing Hesitation Then Not Stating Relay Was About 15.99 At Checkers
Old May 21, 2005 | 11:20 AM
terrmat's Avatar
terrmat
since you found water in your fuel system,you probably need to flush it.
another thing is you probably have way to big of an exuast system for the 300.
When you are running the small 300 you have to keep in mind,with the three inch exuast you are not giving the engine very much bckpressure to run.If it were me the biggest I would go with it would be about 2 1/2 inches.
Old May 27, 2005 | 02:44 AM
OrdoDraconis
let me refrase what is said i found one of the problems the relay full of water was my fault cause its normally its hooked to an air box with another relay by that i cannot identify so i dont know how to replace it know one can idetifiy it.anyways that little junctuion box got turned upside down and it filled with water from rain, so there aint water in the fuel system just in the relay. second problem stupid cutoff switch died as well so i closed the circuit and that works but no it seems that it wants to die after warming up if it dies it a pain in the @$$ start up again checked compression it okay plugs wire, im gonna get to the cap and rotor this weekend as but im still kinda unsure about what it could be im gonna take off my throttle body and clean it too, maybe that will do something, as for that other relay i have know idea what it is but i guess i could open my haynes manula and check the wirring diagram for that any other ideas?
oh i think im gonna go with the staight pipes to the x shape for exhaust in my city we dont have an noise ordanace or emmisions testing so i can play alittle.
Old May 28, 2005 | 11:33 AM
OrdoDraconis
well i changed out the cap and rotor today there some rust and carbon on them both the throttle body gasket is shot as well so i have to wait on that from checkers i maade checkers match the price on a accel cap and rotor from summit racing they had it for 39.99 and i got i 17.99 i keep you all posted on how it goes i also found the headers i wanted on summit hooker headers i have been looking for them for a while.
Old Jun 1, 2005 | 02:33 AM
OrdoDraconis
Well I Figured It Out My Cat Is Plugged Up And It Cause To Die I Pulled The O2 Sensor Out And It Did Better So Now For Exhaust Im Thinking True Dual Into Flowmaster 50 Series Comming Out Behind Each Tire.
Old Jun 20, 2005 | 07:05 PM
OrdoDraconis
well my cat wasnt the problem either but at least i conviced my girlfriend to let me get a new exhaust no i have a true dual with 30 inch glass packssound unique well im still stuped however on the problem
how can you test a bad fuel pressure regulator, and a MAP Sensor what about the o2 censor
hell i dont knwo some throw me a frickin bone here i dont have acces to a code reader i dont think it would help has any experieceed this issue?
Old Jun 20, 2005 | 08:45 PM
OrdoDraconis
well i just tryied sparying stating fluid in it and it stated then died just kept doing that, then i pumped the gas and it trys to go but wont:{
Old Jun 20, 2005 | 10:47 PM
OrdoDraconis
If You Would Like To See How My Air Intake Is Setup You Can Goto My Gallerie And Look There Along With My Crankcase Breather.
Old Jun 21, 2005 | 03:21 AM
OrdoDraconis
Angry
TO CAP UP WHAT I HAVE DONE
Cap, rotor, wires, plugs,
TB Gasket
new exhaust
new fuel pump relay
clsoed the circuit on the emergency cutoff
closed circiut on the Netrual saftey switch,
fixed the the Y hose going to my TB
alternator
battery
fuel filter
exhaust manifold gasket
vavle cover gasket
any thing else i could try to fix it
Old Jun 21, 2005 | 03:25 AM
OrdoDraconis
