electrical upgrade
Old May 9, 2005 | 09:11 PM
Jon Henry's Avatar
Jon Henry
Question electrical upgrade
I'm putting in all new wiring and going from 6V to 12V. Some have suggested re-winding the old gen. to keep the vintage housing, sounds logical. Then what about reducers and resitors and drops and all that stuff??? Is there a decent book or manual I can refer to? The more I look into this, the harder it seems to do! I'd like to do most of this myself but not spend all summer and a pile of cash trying to figure it out. Any help would be appreciated!! Thanks-JH
Old May 9, 2005 | 11:37 PM
46yblock's Avatar
46yblock
This subject has just been discussed on another forum (not FTE). Price certainly can add up. The generator rewind sounds significant but dont know. 46fordtruck said that runtz units can be used to protect your gauges. As I understand it one runtz per gauge. If you have a Ford a new 12 volt sending unit can be bought for the gas tank (around 40.00). If you need a good coil I have three (5.00). New Ballast resistor of 1.5 ohms. New light bulbs and regulator. Stick with your current 6 volt starter. If it is in good condition it will last a long time even with the 12 volt conversion. I think the starter solenoid needs changing. 846-9018
BOL
Mike
Old May 10, 2005 | 06:53 PM
46yblock's Avatar
46yblock
Book
This information was provided by kooltrucks on another site. Speedway part number 910-85180, "The Official 12 volt Conversion Guide". 11.95. They also have Runtz units. www.speedwaymotors.com
Old May 15, 2005 | 11:30 AM
Jon Henry's Avatar
Jon Henry
Thumbs up 12V conversion
Thanks Mike: I got the book and it's easy to understand and helpful. Now all I need to do is pick a place to start and bite the bullet!! See ya~Dan
Old May 15, 2005 | 08:26 PM
46fordtruck's Avatar
46fordtruck
If you want the stock look of the original style generator, check out www.powermastermotorsports.com they make an alternator, but it retains the look of the stock flathead generator. The Runtz are easy to install, and protect your gauges in ways the standard reducer will not. I have installed them in one of my '46 pickups.
Old Jun 7, 2005 | 04:52 PM
trucktex941's Avatar
trucktex941
12 Volt conversion
Saw the notes and thought my insights, having just done a 6 to 12 volt conversion could be helpful. The generator rewind cost me a $106.00 plus and when I was ready to add A/C it had to be reomoved and make room for the AC compressor. The first real question to ask yourself is do I want to retain the original look or would after maket gauges and dash plate be more cost effective. Do you plann on rewiring the entire vehicle? Most wiring harnesses from the 50's or earlier are pretty well worn out. I went with EZ Wire, Dolphin Gauges and for a fisrt time novice it came out fine. In addition to a new 12V sending unit for fuel, you will need a new one for oil and water. Then a 12 volt voltage regulator, and a resistor for the coil and a new solinoid. I did keep, untouched my 6-8 volt starter. If it is not broke don't change it. I concur with the replacement of all bulbs, headlight, tailight, barke lights, instruments, parking, turn sigrnal and license plate holder. I do believe that all of the current, OEM, gauges will require a reducer from 6 to 12 volt. Trucktex941
Old Jun 10, 2005 | 11:52 AM
41inWV's Avatar
41inWV
I did the 6 to 12 volt conversion on ,y '41 a couple of years ago. I replaced the guage panel and inserted new VDO guages, trashed the generator for an alternator (mounted front and center just like the generator (brackets available from Red's headers , Patrick's and others. Rewired with a new Ron Francis kit.
As for a 'strarting point'........ A good pair of side cutters and have at it.
XbigXredX
Nov 10, 2012 11:00 AM
ChrisCarter
2004 - 2008 F150
Jun 5, 2011 05:26 PM
BroncoEx
Modular V10 (6.8l)
Oct 24, 2007 11:57 PM
jmannz25
Modular V10 (6.8l)
Oct 1, 2007 04:45 PM
bigblock_drock
Modular V10 (6.8l)
Jul 24, 2007 07:40 PM
