1992 E350 Van Transmission
Old May 9, 2005 | 07:33 PM
gt5-33's Avatar
gt5-33
I have a 1992 E350 van with the 460 CI motor. We just returned from a race pulling a box trailor. No problems during the trip. When we got home and were backing the van into the driveway the transmission started making a noise like vacuum leak. After several minutes transmission fluid was leaking out of the rubber inspection plug located on the bell housing. The transmission still works fine. Any suggestions as to the problem? Thanks
Old May 10, 2005 | 06:46 AM
Crash687's Avatar
Crash687
how is the fluid level in the trans?
do you have a trans cooler?
Old May 10, 2005 | 07:12 AM
Casey's Avatar
Casey
The trans overheated while backing a load. Not at all uncommon. More trans cooling will help, a fan on a better cooler will help even more.
Old May 10, 2005 | 11:48 PM
Clubwagon's Avatar
Clubwagon
Actually, it sounds more like you got it hot on the way home. Most likely it started the front seal leak on the trip home and only showed when you were manuvering slowly. It took a little time to collect enough fluid in the bell housing before it would leak noticably out the plug.
Remove the rubber plug and go drive it and inspect for more leaking. Towing a heavy trailer will run the trans hot and cause a front seal leak.
Steve
'95 Clubwagon XLT
Old May 11, 2005 | 01:15 AM
Bear River's Avatar
Bear River
Former ******
I agree with the above posts. If I where you, I wouldn't ow any heavy trailers with any vehicle unless I had a heavy duty transmission cooler. I want to install a new cooler on our '92 Superclubwagon, and install a transmission temperature guage.
Old May 11, 2005 | 01:47 AM
38fp's Avatar
38fp
Too HOT
Logging in for gt5-33...........drove the van, and all is well. I will have the system transfused with new oil and install a larger oil cooler. It seems that it got warm on the way home (about 3-5 hours) and then stopped and started backing in and out of the driveway to park the trailer. That is when the oil leaked. I live very close to the highway so it had little time to cool before the trailer parking. I checked the codes and there were none or 111
Thanks guys, you saved me a tow and possible over charge on service.
Dan
Old May 11, 2005 | 07:13 AM
Crash687's Avatar
Crash687
if you are going to change the trans fluid, drop the pan and change the filter while you at it.
Old May 11, 2005 | 01:29 PM
38fp's Avatar
38fp
What cooler is best?
So, does anybody have a preference in trans oil cooler brands that have worked well and are easily installed correctly.
Krone100
38
Aug 5, 2017 05:34 PM
demi134
1997 - 2003 F150
Sep 9, 2016 10:12 PM
Big Van
Feb 19, 2016 03:49 PM
Bennybenbear
Nov 12, 2015 10:39 AM
DavidSeong
Aug 28, 2006 10:05 PM
