351w and 302 Flywheels the same?
Old May 9, 2005 | 06:26 PM
70T351W's Avatar
70T351W
Is there a difference between an 85 351w flywheel and a 70 302 fly wheel?
If so then whats the difference and why would it not work?
Thank Tony
Old May 10, 2005 | 11:42 AM
Kemicalburns's Avatar
Kemicalburns
351w 28oz imbalance 302 50oz imbalance.
if you use the wrong imbalance you may end up picking parts out of your oil pan lol
Old May 10, 2005 | 12:40 PM
ronclark's Avatar
ronclark
There isn't a imbalance difference between a 85 351 and a 70 302. They both used 28 oz imbalance. The 302 changed to 50 oz imbalance in 81. There may be a difference in the number of teeth on the flywheels and the diameter of the flywheel depending on which trans was behind the flywheel and on the size of the bellhousing.
Old May 10, 2005 | 12:42 PM
70T351W's Avatar
70T351W
after doing the rebuild on my 351w i must have got the 302 flywheel mixed up with the 351w and put the 302 fly on. It never ran good at all and there for I never drove it except around the block about 5 times trying to figure out what was wrong. right now i have everythig ready to pull the motor out and replace the fly. should i be concerned with any possible damage? If so what should i be looking for?
Old May 10, 2005 | 12:51 PM
70T351W's Avatar
70T351W
the suspected 302 flywheel does have a considerable larger weight than the 351w.
Old May 10, 2005 | 01:05 PM
ronclark's Avatar
ronclark
If you put a 50 oz inbalance where a 28 oz inbalance goes then you should be getting a lot of engine vibration.
Old May 10, 2005 | 01:43 PM
luvinfords's Avatar
luvinfords
I had a 351W flywheel on a 302 and it shook like a seriuos drag car, they call it the "Death Shake". It will eventually cause premature bearing failure on yer bottom end if it is not taken care of. But if you have only driven it for just a few miles , then you should be A ok. Do the swap and that will get things a little smoother for you.
Old May 10, 2005 | 02:11 PM
70T351W's Avatar
70T351W
It does do some shaking and has hesitation just as the throttle is increased. Does this like the culprit?
Thanks for all of everyones advice
Old May 10, 2005 | 02:57 PM
Kemicalburns
your timing could also be off giving the impression you are having a problem
tony paul
Dec 23, 2014 11:13 AM
huggyb1972
Jan 23, 2014 05:03 PM
briank
15
Oct 18, 2008 11:07 PM
serian
May 19, 2002 02:08 AM
