Offroad & 4x4
Death wobble fix
Old May 9, 2005 | 01:55 PM
bonechief's Avatar
bonechief
Death wobble fix
Somewhere on here i read how to fix death wobble on kingpin 60 by putting washers in the king pin ends.....Can some one give me a detailed description on how to do this............
Old May 9, 2005 | 02:56 PM
fishmanndotcom's Avatar
fishmanndotcom
unbolt the 4 bolts on top of the king pin cap, drop in 1/8" thick (about) spacer on top of the spring whether it be a few bumper washers or a small piece of tube cut to 1/8" thick or anything else you think might work. then just bolt the caps back on
-cutts-
Old May 9, 2005 | 03:09 PM
proeliator's Avatar
proeliator
If that isn't clear enough to a search for it here in the offroad section. Back when fishy was having problems with it I outlined it pretty clearly in a post and the cure worked for him. Its really just as simple as fishy outlined, provided everything else (tre's) are in good shape.
Old May 9, 2005 | 03:19 PM
bonechief's Avatar
bonechief
Thank you both all your information has been a big help......Should i wait and see if i get DW or should i just go ahead and do the mod now.......Im one part away from starting my SAS.....
Old May 9, 2005 | 03:35 PM
proeliator's Avatar
proeliator
What size tires will you be using? If you plan on running large tires then it would be smart to add more preload to the spring as a preventitive measure. If your going to be running small tires, say, a 38" on down you probably don't need the extra preload. Its enough enough to add it later if you find you need it.
Old May 9, 2005 | 03:46 PM
bonechief's Avatar
bonechief
im thinking about Buckshot radials the 305/85/16....Which is about a 36....All im missing to do the SAS on my truck is the u bolt plate on the drivers side when i find one of those and start leave im going to do the swap....im just trying to get all the little things done right now.....
Old May 9, 2005 | 05:02 PM
proeliator's Avatar
proeliator
If your kp are tired, go ahead and rebuild them but you shouldn't need to shim the spring running 36's.
ItsMREMT
Nov 15, 2015 05:59 PM
PinkyRingz
6.4L Power Stroke Diesel
Oct 17, 2015 01:27 PM
66 BADBOY
Aug 24, 2015 10:46 AM
scraprat
6.2L V8
16
May 14, 2015 07:17 PM
DieselVol
Sep 21, 2014 12:11 AM
