Cab Smell
Old Jul 5, 2005 | 10:05 PM
MRKnight's Avatar
MRKnight
I just had mine changed (10,000 miles) with Rotella T and the smell has not re-appeared...
Old Oct 4, 2005 | 12:46 AM
Ford-Red's Avatar
Ford-Red
Quick comment. 2005 PSD with 14,000 miles. I too smelled diesel exhaust fumes at first then later. I reported the smell when at high altitude (Tahoe) to dealer and told him that after I got home, I spotted black soot on both exhaust manifolds. Also mentioned that a TSB I found states that gaskets should be installed if smell is noticed. Gaskets were then replaced without further discussion.
Old Oct 4, 2005 | 08:50 AM
sgthawkusmc's Avatar
sgthawkusmc
Originally Posted by jkmcgrath
Like you were running alcohol in a latemodel stockcar lol
Best description yet. I LOVE that smell! I smell it once in a while, but never in the cab with the windows up. Definitely exhaust. I was pretty psyched the first time I smelled it. Makes the garage smell better
Old May 29, 2011 | 09:55 PM
Dieselhound's Avatar
Dieselhound
Smile Finally got rid of the skunk smell in my cab
I suffered with the persistent skunky smell in the cab of my late 04 6.0 diesel and it only went away when I had a leaky hydroboost unit replaced last week. The hydroboost is the brake booster that receives pressure from the power steering pump. It is mounted right next to the brake fluid reservoir. The reason it stank is because it was leaking Merkon 5 Automatic transmission fluid which stinks like a skunk. The Merkon SP ATF fluid in the transmission also stinks like a skunk and some say that they call it SP to stand for "stinky poo".
I also had a leaky pressure hose that runs from my power steering pump to Hydroboost. I replaced that with a hose from NAPA auto supply which was a stronger hose than my original hose which was crippled with a worn out quick release fitting on the connection to the PS pump.
I am so happy now that the skunk is gone from my truck.
olfordsnstone
Dec 26, 2015 10:45 AM
Rudiak
6.4L Power Stroke Diesel
Nov 9, 2015 07:14 PM
Janatur
2009 - 2014 F150
Sep 19, 2014 04:22 AM
3KP
May 5, 2014 12:36 AM
neverquit5
2004 - 2008 F150
Jan 3, 2010 05:37 PM
