anyone know how to reset the service light on a volvo 2003 s40? it comes on every 7500 miles(volvo oil change schedule) and the dealer won't help. thanks
I know on my cousins Alero there is a reset button for the SERVICE light in the fusebox. You turn the key on and hold the button until the light flashes.
If there isn't a procedure outlined in the owner's manual, then it's like a BMW and you need a special plug in tool to reset it.
How is the dealer not being helpful? Are they not resetting it, or not telling you how to reset it?
I poked around on the web and found this. http://www.volvoclub.org.uk/site_map.htm
S40/V40 SERIES SERVICE LIGHT RESET RESETTING SERVICE LAMP ON 1999 S40/V40 1, Hold down the odometer button 2, Turn the ignition so all the lights come on 3, Keep holding the odometer down for 30 secs or until the service light starts flashing 4, Release the odometer button
hope this helps
Reason: web address
