Ford 300 vs. AMC 258
You can convert the positive stop rockers to adjustable.
You can do it the fancy way with poly locs, or whatever,
or do it the cheap way which is what I did. Just use two
rocker nuts per rocker. The first is installed as normal, and
adjust the valves to your liking. Then take the 2nd nut, and
install it *inverted*, and use it as a lock nut. You have to hold
the bottom nut with a wrench, to keep it from moving, while
you tighten down the top inverted lock nut. I've been doing
this for about 2 years or more, and have only had one come
loose, and I think thats only cuz I didn't tighten the top nut
as tight as I should have...It was one of the first I did...But
that was months ago, and haven't had any problems with any
others, or that one since. You could use some loctiight if you
wanted a bit extra holding insurance..I did this on mine, cuz
I wasn't satisfied with the valve adjustment..Some valves were
too tight, and I prefer to adjust, rather than change pushrods...
I keep my valves only about 1/3 turn down from zero lash....
MK
MK
RamblinMan1963
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
02-01-2018 10:00 PM
Thudpucker
41
07-08-2009 01:46 PM
