Dieseling!
Old May 6, 2005 | 11:10 AM
savage066's Avatar
savage066
Cool Dieseling!
anybody know how to stop run-on effectively? i have a remanufacured YF-1A on my 300 and no matter what i do, it diesels after i shut the engine off. Timing is stock at 6 degrees BTDC, i set it recently. i'm not sure if the mixture is too rich...the exhaust doesn't smell like it is. either way, if i lean it out, it starts running rougher. is this just an old 1-barrel issue or is there a carb problem?
Old May 6, 2005 | 02:49 PM
Boss50's Avatar
Boss50
Theres something on the carb that is suppose to keep it from doing that. I just leave my truck in Drive when I shut it off and it doesn't diesel.
Old May 6, 2005 | 03:06 PM
n9lhm's Avatar
n9lhm
Dieseling is usually an idle speed issue -- how fast is it idling? What year is it, did it have a throttle stop solenoid on it to begin with? Brian
Old May 6, 2005 | 03:08 PM
daveee's Avatar
daveee
I have somewhat the same problem on my 78 F-150 4x4 when I have it checked for Arizona emissions. In order to pass, I must lean it out 1/2 turn and increase the throttle adjustment 1/2 turn. It then diesels when I turn it off. In order to prevent the dieseling I must richen it up and turn down the throttle, but then I flunk emmissions. Timing is at 6 BTDC also. I would appreciate any ideas for a permenite solution
Old May 6, 2005 | 06:51 PM
tetraruby300's Avatar
tetraruby300
Incorrect timing can also cause dieseling.
Old May 6, 2005 | 08:11 PM
daveee's Avatar
daveee
The spec is 6 degrees BTDC. That is my point. It is not incorrect timing.
Old May 6, 2005 | 10:58 PM
oldhalftons's Avatar
oldhalftons
run it at 10-12 BTDC and back off the idle screw to lower the RPM back to where it was before it was increased by advancing the timing.
It will stop dieseling.
Old May 7, 2005 | 11:17 AM
savage066's Avatar
savage066
cool, i'll give it a shot!
hwybee22
Feb 20, 2025 09:04 AM
HEADQUARTERS42
General Diesel Discussion
23
Feb 9, 2022 07:21 PM
Raven17
Dec 17, 2017 05:06 PM
JESTERxHEAD
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Feb 22, 2013 09:54 PM
1flyfisher
Oct 25, 2004 06:37 AM
