Return on investment!
Old May 4, 2005 | 09:08 PM
Steve78's Avatar
Steve78
I know everyone hates these types of questions, but... If you take a stock 78 I-6 w/ approx 55-60k on stock rebuilt and add:
  1. Headman headers into a single 2.5" pipe w/ a decent muffler
  2. Edelbrock 500 performer
  3. Offy d/p
  4. better dist w/coil
What type or hp/fp are we looking at?
Does a different cam add that much? If so what type is best to retain, but enhance the built in characteristics of the I-6. Would I need to change the stock rockers and push rods?
I have heard conflicting views about adding larger valves than stock issued. What is the final verdict and is it worth it?
Thanks....New to this and I would like to spend my money wisely, if there is such a thing.
Old May 5, 2005 | 08:16 PM
Steve78's Avatar
Steve78
I know someone must have some insight into this matter.
Old May 5, 2005 | 08:26 PM
Gerry Lutz Jr.'s Avatar
Gerry Lutz Jr.
I'm guessing about 220 hp and 315 lbs. That's off the top of my head though and probably a bad guess at that. Anywayz i'd have someone with a desktop dyno run it if i were you. I'd swap the cam out too it all depends on what kind of performence you want. wether it be down low torque upper rpm speed or just the choppy idle sound. You can still stick with your stock rockers and pushrods i would think too.
Old May 6, 2005 | 08:58 AM
Argo's Avatar
Argo
Actually, take a look at this month's Hot Rod. They did a buildup on a Chevy 292. Yeah, I know, not the same thing, but you'll gain some valuable insight into the strengths and weaknesses of a big six. One problem is due to the length of the engine. With a central carburetor, cylinders 3 and 4 will run too rich, cylinders 2 and 5 will be just right, and 1 and 6 will be too lean. Multiple carbs or EFI are better. Doesn't mean it won't run well without it, but it will be a compromise. Because of that, I'd estimate about 185-200 horsepower and 300-325 lbs/ft of torque, with a stock cam, where a V6-V8 might make more horsepower, like 210-230.
Old May 6, 2005 | 10:02 PM
Steve78's Avatar
Steve78
since the rebuilt only has 55-60k, I should be able to just R&R the cam and lifters and keep the rockers and pushrods, right? I'd like to keep the tork down low, but would a new cam make that much of a diff?
Old May 7, 2005 | 12:07 PM
Argo's Avatar
Argo
since the rebuilt only has 55-60k, I should be able to just R&R the cam and lifters and keep the rockers and pushrods, right? I'd like to keep the torque down low, but would a new cam make that much of a diff?
More lift with similar overlap and duration should boost torque over the curve,boost horsepower and preserve the low end power of the engine, assuming that the head and intake are capable of flowing the additional air/fuel mixture that the cam is capable of delivering, and assuming the exhaust can flow the additional burned gasses afterwards.
