Sponsored by: Kumho
98 expedition help...
Old May 5, 2005 | 03:27 PM
hecgar791's Avatar
hecgar791
i just got this 98 expy and its makin some loud noise when i start it up, i took it back to the dealer and was told that it was the air suspension leveling it out, the noise only lasts for like 30 secs and turns off.. i hopped in my aunt's expy and hers doesnt make that noise. is this really normal or is the dealer tryina rip me off???
Old May 6, 2005 | 06:19 PM
SRD4X4's Avatar
SRD4X4
It is normal,to a point.The system will kick on when it needs to.If yours is doing it everytime you start it and it hasn't been sitting for a long period of time,then there is a leak in the system causing it to bleed down.
Old May 6, 2005 | 06:24 PM
peppermrj's Avatar
peppermrj
Check the mounting for the air compressor. They can rattle like heck if loose. Put the 2 side by side and compare them. Then go back the the dealer. Take both expys if need be. If the compressor is going bad I'm sure they are at least a $200.00 item.
Old May 6, 2005 | 06:29 PM
peppermrj's Avatar
peppermrj
My sons 85 cont will bleed down automatically after it has sat for only a few minutes. It is by design. It also inflates breifly when restarted to re-adjust for the added weight.
Old May 6, 2005 | 06:34 PM
peppermrj's Avatar
peppermrj
Welcome to the boards.
jschoolf
Jul 6, 2009 09:50 AM
noitidepxe 89
Sep 3, 2003 08:51 PM
GypsyKat
Jul 23, 2003 06:25 PM
