302 4bbl carb swap.
Old May 3, 2005 | 10:54 PM
5x5F150's Avatar
5x5F150
302 4bbl carb swap.
hey guys just wondering, if i swap out my 2bbl for a 4bbl will my car run alright? I snaged both from a local u-pull-it and the intake is from a 5l but the 4bbl is off a 460. How much tinkerig will i have to do? Will bolting the carb on make it go or just sputter fart and die? its in a little mustang and is supposed to be the donor engine for my ranger eventually. I want more go and i dont care how much gas i burn-if i wanted fuel mileage i would buy a volks tdi.
Old May 4, 2005 | 01:16 PM
smoke n tires's Avatar
smoke n tires
if its a 302 manifold and a 460 carb with the big rear barrels then you might be able to get an adapter from MR GASKET. i would recomend a 600 holley with equal size barrels it will bolt right on.
Old May 4, 2005 | 05:14 PM
quehele's Avatar
quehele
I had a 4 bbl on my 67' Bronco with a 289 (same as a 302) and the trick set-up for me was a Carter 4-bbl. It wasn't a spread-bore like the Motorcraft you "pulled" but it worked perfectly for a lot of years. Besides, as I remember, the 4 bbl manifold for a 289/302 is a 4 hole, non-split plenum pattern -- not a spread-bore dual-plenum.
According to the Holley Selection Guide, a 302 that's "Mild" (stock) should have a 390 cfm Carb. and one that's "Hot" (modified) should have a 600 cfm. Only a "Wild" (Competition) engine calls for a 650 cfm or larger Carb. If you have a Motorcraft for a 460, you probably have too much Carb. for the Cubes.
Hope this helps.
Jim
Old May 5, 2005 | 10:43 AM
smoke n tires
a stock motorcraft 460 carb is 605 cfm, the only true way to tell how much carb you need is to experiment.
Old May 5, 2005 | 11:10 AM
5x5F150's Avatar
5x5F150
thanks 4 the input. I plan on trial and error with the carb i have, and if it doesn t work then ill use some of the ideas you all gave. The gaskets i have line up and the carb works fine on the intake i just wasn't sure if it was going to make the engine bit more than it could chew. im going to try it will update on my success or failure
Salomon Trujillo
May 5, 2013 03:20 PM
Butl85
Jun 25, 2007 04:08 PM
icuhatn99
Feb 5, 2006 10:35 PM
Antogt
Mar 12, 2005 09:58 PM
rticwrrior2000
1978 - 1996 Big Bronco
Jul 31, 2003 04:13 PM
