Timing issue
Old May 2, 2005 | 06:54 PM
hoxiii's Avatar
hoxiii
Timing issue
Allright, so my truck started acting goofy not running right so i started checking things out. I got to the distributor and noticed the clamp was loose and allowed the distributor to slightly move. No biggie, I'll just time it and tighten it down, no problem.
Well, slight problem. There is no timing mark on my crank pulley. I scraped it, i cleaned it, i did everything to try to find it and there just isn't one on the pulley.
So here's my question: Does the keyway line up with TDC #1? If it does i'll just whip the pulley off and make my own mark, if not I guess I'm just in for a bit of fun trying to accurately place a timing mark on a featureless surface. Joy.
Justin
Old May 3, 2005 | 09:47 AM
teds74ford's Avatar
teds74ford
I haven't figured out the timing on mine either. What I have done for now is fiddle with it until it runs good, but that is nowhere near as accurate as timing it.
Old May 3, 2005 | 09:50 AM
hoxiii's Avatar
hoxiii
i got it so it doesn't audibly ping, but it still doesn't run well at all. Will barely pull 55 down the highway.
Justin
Old May 3, 2005 | 12:06 PM
teds74ford's Avatar
teds74ford
mine is similar. It doesn't like the higher rpms. I think the timing gets too advanced because of the vacuum.
KsCop
40
Jan 8, 2014 12:38 PM
backbonejay
Apr 12, 2013 04:31 PM
ErrorS
1978 - 1996 Big Bronco
Oct 28, 2009 03:14 AM
87_gt
Apr 9, 2009 09:49 AM
FordMan2
39
Jul 24, 2007 02:44 AM
