Tranny swap
Old Jun 20, 2000 | 08:10 PM
needanswersplease's Avatar
needanswersplease
Tranny swap
I have a 91 f-150 w/302 and e40d need to know what is required to replace trans with a c-6 or if it can even be done
Old Jun 24, 2000 | 09:27 PM
needanswersplease
Tranny swap
To anyone wondering,yes the swap can be made.
It will require a 3 and 1/2 in lengthen to the driveline,shaving 1/2 inch off of the rear cross member,adding a throttle position cable,and a modification to the shift linkage and neutral safety switch.This will only work on a 91 or older. The transmission can be as old as 1970's The total cost with a salvage transmission for mine was under $400 for a proven strong transmission,which is a lot better than $800-$2200
for a transmission proven to be troublesome.It requires no computer change what so ever.
Old Jun 25, 2000 | 12:01 PM
Ron's Avatar
Ron
Tranny swap
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
