Sponsored by: Auxito
Dpfe
Old May 2, 2005 | 12:32 AM
2000 F-150's Avatar
2000 F-150
Dpfe
I tested my DPFE and only got a little over 3 volts so I replaced it. Now my transmission shifts really smoothly. Coincidence or resetting the PCM afterwards?
Old May 2, 2005 | 08:40 AM
projectSHO89's Avatar
projectSHO89
Neither. Most likely, the DPFE was defective (happens a lot).
I'd consider it a successful repair!
Steve
Old May 2, 2005 | 12:00 PM
ealopez's Avatar
ealopez
What is DPFE???
Old May 2, 2005 | 04:22 PM
Glock's Avatar
Glock
<TABLE style="WIDTH: 266pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=354 border=0 x:str><COLGROUP><COL style="WIDTH: 48pt" width=64><COL style="WIDTH: 218pt; mso-width-source: userset; mso-width-alt: 10605" width=290><TBODY><TR style="HEIGHT: 15.75pt" height=21><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=64 height=21>DPFE</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 218pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=290>Differential Pressure Feedback EGR sensor.</TD></TR></TBODY></TABLE>
Old May 2, 2005 | 08:00 PM
FoxyFord83's Avatar
FoxyFord83
Guess that could be my problem. I had to replace a hose going to it. Caused a check engine light. How much was the new DPFE?
Old May 3, 2005 | 10:48 AM
2000 F-150's Avatar
2000 F-150
Foxy,
Found it at "National Auto Parts" website http://www.trademotion.com/partlocat...?siteid=214126
for $48.00 Motorcraft original parts. I did notice that mine did rattle a little when I took it off and the new one didn't.
My local dealer wanted $106.00 for a new one and I knew that I had seen it for at least $65 or $70 at RockAuto.com or one of the other places, but National was the cheapest by far. $56 w/ freight. It didn't fix what I wanted it to fix, but it did fix the other problem that I had.
Good Luck!
Old May 3, 2005 | 11:27 AM
FoxyFord83's Avatar
FoxyFord83
ok thanks. i will check on that this week..
Old May 3, 2005 | 11:56 AM
ealopez's Avatar
ealopez
FoxyFord let us know if works!!!
Old May 3, 2005 | 02:10 PM
2000 F-150's Avatar
2000 F-150
Thanks again (by the way) projectSHO89. I appreciate your help and didn't mean to be rude by not answering sooner!
