I was wondreing if there is a ford car websight like this one. This place has helped me greatly with my truck. Now the wifes sable is giving me problems. Had the alternator and power stering pump replaced and its still makes this horrible high pitch wineing noise . If anyone nows of a website or has had this problem. Any help would be appreciated
Sounds obvious, but were the other accessory-related pulleys checked for the sound, such as that of the A/C compressor, and the idler/tensionser pulley, when the other repairs were done? Pulleys that are out of alignment will cause the belt to squeal, too. Speaking of which, what is the condition of the accessory belt itself?
If your Sable has the 3.0L OHV engine, another source of a squeal-like sound could be a bad camshaft synchronizer and/or sensor assembly, although that usually throws a code:
