General Automotive Discussion
Sable problem
Old May 1, 2005 | 10:36 AM
valo's Avatar
valo
Question Sable problem
I was wondreing if there is a ford car websight like this one. This place has helped me greatly with my truck. Now the wifes sable is giving me problems. Had the alternator and power stering pump replaced and its still makes this horrible high pitch wineing noise . If anyone nows of a website or has had this problem. Any help would be appreciated
Old May 1, 2005 | 10:47 AM
Smaug's Avatar
Smaug
I used to visit this one
http://www.taurusclub.com/forum/index.php
Old May 1, 2005 | 11:19 AM
kameronth's Avatar
kameronth
Use a stethescope to try and find the squeal. I just replaced a water pump on a friends Sable because it was sqealing like crazy.
Old May 2, 2005 | 06:18 PM
Rockledge's Avatar
Rockledge
I agree, you really need to isolate the noise.
Sounds obvious, but were the other accessory-related pulleys checked for the sound, such as that of the A/C compressor, and the idler/tensionser pulley, when the other repairs were done? Pulleys that are out of alignment will cause the belt to squeal, too. Speaking of which, what is the condition of the accessory belt itself?
If your Sable has the 3.0L OHV engine, another source of a squeal-like sound could be a bad camshaft synchronizer and/or sensor assembly, although that usually throws a code:
https://www.ford-trucks.com/forums/s...d.php?t=202004
Old May 3, 2005 | 03:49 AM
rebocardo's Avatar
rebocardo
I have seen squealing cars where the belt was off by one rib. Which causes it to rub the top against the rust ridge on the idler.
