Water Bottle plastic question
Old May 1, 2005 | 10:33 AM
YOMAN's Avatar
YOMAN
HI,
I left approx 15 water bottle (plastic) "polard water" for couple of months...
is it safe to drink water? its not open, fully closed.
I know can/glass is best but plastic ?
Thanks!
YOMAN!
Old May 1, 2005 | 10:37 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Why not?
My company has a 'Shelter in Place' program, in case of some sort of terrorist attack.
We have pallets and pallets of bottled water stored in the building. (MREs, too.)
The company does rotate the stock every six months, though.
At the moment, I have 4 cases of bottled water in my garage.
IF the water is cool, sealed and un-tampered with, I see no reason that 'a couple of months' would hurt anything.
My 2¢.
Old May 1, 2005 | 10:59 AM
Jmatteau's Avatar
Jmatteau
Should be fine.
Old May 1, 2005 | 11:21 AM
jim henderson's Avatar
jim henderson
If the bottle is a factory sealed bottle it should be good for quite awhile. If it was opened once then it is questionable.
You can store water by just putting a tiny bit of regular(non scented) laundry chlorine bleach in a gallon bottle. I forget the exact amount but I was told that when you empty the bottle, there is enough left in the bottle to do the job. A web search will probably turn up the exact amount for you.
On my travel trailer, I put just a few teaspoons into our 50g tank if I think it will sit awhile.
Good Luck,
Jim Henderson
Old May 1, 2005 | 02:30 PM
Mil1ion's Avatar
Mil1ion
They also sell " making potable water " treatment capsules at most camping equipment stores.
Old May 1, 2005 | 03:27 PM
Flip4ford's Avatar
Flip4ford
If you filled the bottles yourself, toss them. It is a factory job, it is OK.
Old May 1, 2005 | 03:47 PM
jake00's Avatar
jake00
the stuff at the camping stores is called polar pure i think
Old May 1, 2005 | 07:27 PM
57_ford's Avatar
57_ford
I think sun light will make water go bad. Back in the old days they stored water in dark glass or clay bottles for this reason. If it wasn't in the sun light I would drink it.
Old May 1, 2005 | 07:33 PM
Mil1ion's Avatar
Mil1ion
Bottled water isn't regulated like other drinking fluids.
Read the label
You are better off filling your own bottle full of R/O water, than buying it from the store
Old May 2, 2005 | 02:01 AM
Greywolf's Avatar
Greywolf
RV filters work well for eliminating most contaminants. They connect to any hose connection and are available at camping world and such places.
Best storage bottles are made of polycarbonate plastic, and have a number seven inside a triangle on the bottoms to identify the material. These do not add anything to the water from leaching stuff out of the plastic, which is why they are preferred by bottled water distributors such as Sparklets, etc...
Old May 2, 2005 | 03:46 AM
Torque1st's Avatar
Torque1st
Posting Legend
Do not fill bottles with your own RO water or tap water and then store them.
Old May 2, 2005 | 10:17 AM
Mil1ion's Avatar
Mil1ion
That's right.
You can bottle them to drink right away
I Should have mentioned that.. Doh!
Old May 2, 2005 | 06:57 PM
Greywolf's Avatar
Greywolf
Distilled is best, in clean bottles.
Old May 2, 2005 | 08:32 PM
5_labsownus's Avatar
5_labsownus
When setting up the sheltering of company employees in the event of an incident! We have several chemical plants here!
We we talked to several bottle water companies and we talked to them and the answer was:
Hard plastic (the drinking bottles you but in the store) are good for 12-18 months if stored out of sun light and in a cool place.
The water in soft plastic (white milk type jugs or bottles) are good for a year but you will get a plastic taste after 3-6 months!
An this is for factory sealed bottles!
Old May 2, 2005 | 09:26 PM
four-sixty-power's Avatar
four-sixty-power
If you buy bottled water, I have a bridge I'd like to sell you!
