rear axle flange
Old Apr 30, 2005 | 11:23 PM
kermit's Avatar
kermit
rear axle flange
hey all, need help again.
i need to know if the pinions between 73 and 76 had different spline counts or not.
here is the deal: i put a different rear end in the truck. bolted right up other than the e-brake cables were too short and got cut, will replace with the ones off of the old rear end. other than that things are going smooth until i try to hook up the driveshaft and find that the new rear end, which came out of a 76, has a different size connection at the pinion and the ujoint on the truck is too big.
i need to know if i take the old one off of the old rear end if it will just slide on and i have to retorque it, or if i need to change u joints, or worse, need a different drive shaft now.
thanks for any help.
jamie
Old May 1, 2005 | 03:42 PM
kermit's Avatar
kermit
well, mission complete, got the yoke swapped out and back on the road.
no difference in spline counts.
bluestang65
Sep 10, 2010 03:45 PM
98SurplusExpy
Feb 4, 2010 11:26 PM
Nightrider41
Jan 3, 2009 09:34 AM
kenz28
Dec 28, 2005 04:26 PM
