1990 f 350 transfer case fork problem
Old May 1, 2005 | 01:04 AM
Clay Hett's Avatar
Clay Hett
I took it apart, the oil pump had spun and the front fork was worn off, (wouldn't stay in gear unless I had power on it) So I replaced these items,, drove 100 miles and it started coming out of gear again,, Now I have it taken apart again and the fork is just about in the same shape as the one I replaced, It appears it is holding the gear in place by itself, and this wears it out,, so I've looked everything over,, circlips where in place etc. now maybe I'm suspecting the planetary gear, or any ideas?? Thanks Clay
Old May 1, 2005 | 11:06 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
