rear dif.
Old Jul 25, 2015 | 09:38 AM
bill rancharo's Avatar
bill rancharo
rear dif.
my 1978 ranchero i'm told has a 9" dif. i want to change it. will the complete rear end from a 1987 Grand Marquis fit and work.
Old Jul 25, 2015 | 12:04 PM
tjc transport's Avatar
tjc transport
i ain't rite
if i remember correctly the Grand Marquis uses a 8.8 rear.
i would stick with the 9 inch, it is a better rear, and has much better aftermarket support.
Old Jul 28, 2015 | 08:46 PM
85e150's Avatar
85e150
Your '78 has coils and control arms as does the Grand Ma. What are the chances all that stuff lines up between a '78 and an '87?
While the 8.8 may have discs and might be marginally more efficient due to a slightly different ring and pinion engagement, as per the prior post, you can get just about anything you want for a 9 ratio wise, disc wise, axle, etc etc. And it all bolts right in....
Old Aug 1, 2015 | 02:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1975/76 Ranchero (Torino) & 1977/79 Ranchero (LTD II): The 9" was the only available rear axle.
AKFORD4x4
Jan 5, 2010 05:06 PM
93PGT
19
Aug 6, 2007 10:53 AM
reed1951
Apr 9, 2007 08:27 AM
factory594x4
1978 - 1996 Big Bronco
Jan 12, 2007 06:31 PM
holla-if-ya-hear-me
Jan 25, 2004 10:22 PM
