That's interesting because last night I tried to see how fast I could get my 05 up to, and it pulled hard until it hit 99.1 on my GPS and flattened out. I didn't know they were limited.
You need to go to the modify tunes section of the Predator when installing the 65hp tune. It will give you the option to remove the speed limiter. When I first got my '03 it had no speed limiter on it til they flashed it the first of several times--then 98 was it. All the factory "tunes" have the speed limiter. The Pred will remove it if you use that option.
