exhaust leak
Old Apr 29, 2005 | 04:13 PM
Quackhead94ranger's Avatar
Quackhead94ranger
exhaust leak
allright guys, i cant take it anymore, one of the bolts that connects the manifold ( i think that's what it is ) to the y pipe has broken off, and it is very very annoying. but the problem is, is that it brok in half, so half of it is still there.
i put a picture in my gallery, so take a look at waht im talking about please!
i am to the point were if i cant fix it ( any ideas on how to fix it? ) i will take it in, but if it comes to that, how much would it cost to get done? thanks guys!
Old Apr 29, 2005 | 08:22 PM
MemOrex's Avatar
MemOrex
Maybe you can drill it out.
Old Apr 29, 2005 | 11:33 PM
kens64's Avatar
kens64
2 possible ideas.
1. LOTS of PB Blaster, let it sit overnight, then try to unscrew it with a good pair of vicegrips. Might also try tapping it with a hammer, and/or adding some heat to it to break it loose.
2. Grind the ends square to fit a wrench on it, and twist away.
Hope this helps.
Old Apr 30, 2005 | 02:28 AM
rebocardo's Avatar
rebocardo
They sell little C clamp things so you can suck that right back up and seal it without removing the stud. It costs about $10.00. It looks like enough stud is left to put two or three nuts on very tight so you can back/pull the stud right out.
It looks like you have enough room in there (more then I ever had with any BII) to cut the ends off and then drill the stud out with a right angle drill or dremel. I drilled from underneath (wearing eye protection) with a 1/2" air drill.
I used (because of space) 5/16s bolts with a 5/16 lock-5/16 flat-3/8 flat washer combo (both sides) to hold the exhaust assembly together after I drilled out the studs. I put anti-seize on the parts and used Grade 5 in case I wanted to break the bolts with an impact if the new bolts/nuts ever seized.
A muffler shop can just MIG weld a new stud unto the old one. Cost will probably be $25 or so depending on the shop.
c delisio
Jan 14, 2017 06:25 AM
Sondre Næss
15
Oct 29, 2016 06:21 PM
medicpg
Mar 11, 2010 07:10 AM
RomerB2
Bronco II
Aug 17, 2004 07:55 PM
rhetor
Electrical Systems/Wiring
Mar 24, 2004 09:14 PM
