Complicated devise or simple mind?
Old Apr 28, 2005 | 06:00 PM
fast freddie's Avatar
fast freddie
I pulled my 30' travel trailer last weekend and had some temp problems on my 95 PSD CC DRW. When I was traveling the secondary roads, no problem but on the interstate running 65'70 mph, the temp would creep up to the top of the gauge. Not overheating but close. When I got home I took a look at the fan clutch and found that I could turn the engine off at normal operating temp and the fan would continue to spin for at least 30 seconds. I said to myself "Self, there is your problem". However, the next morning when the engine was cold, I started the engine, let it idle for a minute and shut it off as I watched the fan. It stopped right away. Little or no free-wheeling. Maybe it's just me but this seems bass-ackwards. I mean wouldn't you want the fan to lock up at HIGH temps and release at low LOW temps? Anbody know how these things work or are supposed to work?
Old Apr 28, 2005 | 08:30 PM
superrangerman2002's Avatar
superrangerman2002
What kind of shape is your fan belt in?
If it's cracked, or you've been putting any type of dressing on, time to replace the belt and clean up those pulleys.
What kind of miles are on your rig??
Old Apr 28, 2005 | 08:46 PM
RedTaurus94's Avatar
RedTaurus94
My fan clutch "seemed" OK to me, but replacing it (after a half-dozen other things) seems to have solved my overheating issues.........
Old Apr 28, 2005 | 09:48 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Self is correct. A viscous clutch shouldn't ever freewheel for more than a few revoloutions.
Old Apr 29, 2005 | 07:14 AM
fast freddie
Belt is new. Got 265,000 miles on her. So, sounds like I'd better get ready to get off of about $200. Would still like to know how the dadgum works...
Old Apr 29, 2005 | 08:51 AM
barebackjake's Avatar
barebackjake
you should be able to hear that fan clutch kick on going down the road to. the one on my truck roars when it kicks in.
i belive thoose ones have fluid in them and once the fluid gets hot enough it expands and locks it up. ive seen the innereds of some big rig ones and they look like a mini tourque converter.
Old Apr 29, 2005 | 04:54 PM
fast freddie
Thanks for the reply BBJ. I looked at a used clutch today and on the back of it there is a strip of metal that lays over the top of a little button. It appears that when the clutch is cold the metal strip lays flat and pushes the metal in. I assume that when it gets warm/hot the metal stip expands and since it is held hard in place on each end, it tends to bow outward and let the button pop out. I don't have a clue what the little button does....
Old Apr 29, 2005 | 06:20 PM
Quadzilla's Avatar
Quadzilla
It dims the dash lights, so you don't have to turn the ****.
Sorry, I couldn't resist.
Old Apr 29, 2005 | 06:30 PM
fixnair's Avatar
fixnair
Smile
If your truck is up to speed you don't need a fan. The fan is only needed at speeds under 30 MPH. I doubt your fan clutch is the problem. Sounds to me more like a fouled radiator.
Old Apr 29, 2005 | 08:03 PM
fast freddie
Touche' Quad....lol. Makes sense Fixnair but I read someone else's post that was basically the same problem and a new fan clutch fixed it. Just a guessing game at this point.... Thanks for the replys.
topshelfcustoms
Oct 21, 2014 05:43 PM
vamstad
Escape & Escape Hybrid
Apr 19, 2011 04:31 PM
1Fordnatic
Oct 9, 2010 04:44 PM
jlmotox
Dec 16, 2009 01:39 PM
mhilow
1983 - 2012 Ranger & B-Series
Dec 20, 2006 08:35 AM
