e-brake setup
Old Apr 28, 2005 | 02:33 PM
oldfords4ever's Avatar
oldfords4ever
e-brake setup
Has anyone pull a disc brake e-brake setup on there truck?
Old Apr 28, 2005 | 02:55 PM
RaleighDad66's Avatar
RaleighDad66
Not many people have posted the addition of rear disc brakes to their 61-66 trucks but most of those that have used a differential with the rear disc setup already in-place. The e-brake typically uses a special internal drum on the rear disc rotor for a mechanical brake instead of the hydraulic system used by the rear disc. The rear end of these trucks are fairly light with the comparison of the overall truck weight and many would argue that the addition of rear discs don't offer much, if any, stopping advantage over conventional drum however, swapping to the wider drum of the 73 - 79 differential does. One more problem will be getting the proportioning valve tuned so the rear disc doesn't lock up before the front.
Old Apr 28, 2005 | 03:31 PM
ZombieSlayer's Avatar
ZombieSlayer
Well I don't know much about brakes, but I when I bought my truck I noticed that it has 4 wheel disc brakes However the ebrake isn't hooked up....yet
Old Apr 29, 2005 | 05:42 AM
oldfords4ever
I am not talking about putting rear disc brakes on my truck
I am thinking of relocating the e-brake setup to the rear output of the transfer case.
Has anyone done this setup?
Old Apr 29, 2005 | 05:53 AM
jowilker's Avatar
jowilker
Oh, You didn't say that, we shoulda been able to read your mind, huh?
Don't recall ever hearing of that being done. Why would ya want to?
John
Old Apr 29, 2005 | 09:45 AM
oldfords4ever
For one thing an e-brake setup that is on the output of the transfer case holds a lot better then a standard setup.
Also this type of setup has been done before, they are used on big truck a lot.
Old Apr 29, 2005 | 10:26 AM
Ringo Fonebone's Avatar
Ringo Fonebone
I had a driveshaft from a big truck or school bus originally on my Merc when I got it, it had been altered to a C6 tranny. It had a drum up on the spline end of the driveshaft that I think was for a drum setup e-brake. Never seen a disc. Check big truck setups in the yards, also where I live there are a boatload of schoolbusses in the yards, try them too.
Old Apr 29, 2005 | 11:04 AM
44dwarf's Avatar
44dwarf
The only problem with that type of set up is if you drop the drive shaft and it takes out the fluid line you have no brakes at all.
I had it happen on my bus on the way home from the auction. I know the ujoint was bad and the shaft bent (former owner ran over something) will it tossed the shaft at 55mph and cut the hyro line i had to coast to a stop hopping the shaft didn't dig in and pogo the 35 foot bus.
44dwarf
PS: bus was made in to race car hauler. sold it cheaper to use the 65
Old Apr 29, 2005 | 11:29 AM
oldfords4ever
You do have a point about dropping the drive shaft. I am going to have to think about this a little more and do some more research.
Old Apr 29, 2005 | 12:59 PM
352 blue's Avatar
352 blue
On 4x4 on spike they showed a disk setup but probably not for our trucks
f1001969mike
1978 - 1996 Big Bronco
May 29, 2012 01:07 PM
drof46
Jan 16, 2010 02:50 PM
vwgtivr
Feb 17, 2009 10:46 PM
65fstback
May 12, 2008 06:37 PM
