Removing a few leaf springs lowers F350?
Hi there,
I am considering purchasing a 2002 F350 CrewCab PSD and I was wondering if the truck would actually get lower if I removed a leaf spring or two :-) The reason I am asking is that it might not fit in my garage if I can't get it lower by a few inches. I realize that I might lose some payload and towing capacity but the F350 already has way more then I would ever need. Any comments, silly or otherwise welcome
It will most likely have 4" block under the spring. You could swap them out with the factory 2" blocks from an F-250 and not lose a thing. It will probably also have B code rear springs which you could swap for the A code springs and minimize the loss of payload and towing capacity while setting it down another inch or so.
Funny
Originally Posted by 96ford4x4turbodiesel
heck if you're gonna take a couple of leaf springs out ups them to my house.... i could always use some extra ones to lift my truck
Not going with the F350
Thanks again for the replies I just wanted to let you know that I won't be going with the F350. It was a 7.3 PSD in case I didn't mention it and I have now tried a 6.0 PSD and I really like the extra power and the (OK some of you are going to make funny faces now) quiter engine.
For the rear, yes the reverse is true.... However, You can not and must NEVER use a block to lift the front. Not even 1" is ok. Doing so puts extreme stress on the front springs when you make turns. Very dangerous idea. If you want to lift the front just a little, get a 3 inch spring hanger, otherwise get a true lift spring.
NotMatt
09-19-2016 07:30 PM
kioolt
10-25-2013 05:12 PM
