...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
In the mean time...tell us more about you truck, any mods.....???
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
BECAUSE ITS A TRUCK!!! Driving a truck is like driving a brick down the road. These trucks are not ment to be good at gas mileage, I get about 11-12 normally. If you have a V8, thats about normal. Get ready to start cryin at the pump, cause these trucks have a little bit of a drinkin problem!!
ummm yea I would be SOOOO happy w/ 10 mpg, my 79 w/ 351M avgs around 5....but on the highway its 7.......YIPPEE....by the way I'm completely broke....I wonder why haha
I used to have an 86 2wd Supercab, 5.0/AOD. Averaged 15-16.5 mpg. (American gallon). Sometimes as low as 14 but I lived in a small village at the time and it would do the lower (14) if I did a lot of city driving. But even THAT included 150 km (90 mi) to GET here! So if you're doing a lot of in town/city I'd say it's about average.
Heh, my 96 F-150, 4x2, 4.9 I-6, M5OD, 2.73 rear gear (the most preferable setup/combo for milage in a 92-96, except mine is a long box, not short box (it is reg cab)), only gets 11.5MPG consistantly. I will be probably redoing the whole exhaust (still has the complete factory exhaust!). I may also purchase new O2 sensors, as I've recently learned they're wear items and mine are factory (9yrs old). I get lean codes once in a blue moon. I also have a fuel filter to go in, but failed the first time I tried removing the old one. I envision my truck getting 16MPG or more city, and 20MPG highway.
my 95 4wd w/ 300, m5od, 3.55's and I'm avg. 10 mpg and lucky to get 200 miles out of the tank. I have the short bed 4wd so I only have the rear tank. I have tried almost everything I can think of and it still sucks.
My 1995 F-150 5.8 with 210K on it with the 3.55 rear end used to get 7-8 MPG combo highway/city miles if I was lucky. Now that its warmed up to an average 60 here in Ohio, and since I loosened up the rear brakes cause they were stickin, put ball joints on it, drained the tranny fluid down to the right amount cause some nimrod overfilled it before I bought it in December, I now average 14.2 MPG. I am shocked. I'm runnin 31-10.50-15's and also forgot to add that I replaced the muffler with a piece of pipe and ran a metal fence pole through the 2nd catylitic converter, which sound decent. I couldnt get to the first cat due to the fact that theres a bend in the pipe between the two cats. Ford musta been thinkin on that one.... but 14.2 is what I just got and I ran it hard (75-85) in some areas....
