power steering
Old Aug 10, 2000 | 09:27 PM
bagman150's Avatar
bagman150
power steering
hello, i have just purchased my first truck. it is a 1986 F150 with the I6. It almost in mint shape. However it didnt come with a lot of options. It does not have power steering. i would like to convert it. i am wondering what exactly i need. also, when i was driving it home the other day after just buying it, i noticed it had a lot of front end play. first thing that i am going to do is replace the inner and outer tie rod ends. does this probably mean that the ball joints are gone? what else can i replace to help fix the problem? thanks for you help!
Old Aug 10, 2000 | 10:56 PM
PAUL_2's Avatar
PAUL_2
power steering
It would be a good idea to inspect all the steering linkage for wear . Its possible the ball joints are worn , but check them for wear before you replace them . Another place to look is the wheel bearings , Im sure it wouldnt hurt to clean & repack them with new grease . As for adding the power steering you ll need a Ps pump , Ps steering box , & a belt . Plus a few hrs to do the work . Have an alignment done once all the work is completed .
Paul
Old Aug 14, 2000 | 07:57 PM
bagman150's Avatar
bagman150
power steering
thanks for you response, i cant wait to start working on it.
Old Aug 14, 2000 | 09:10 PM
nitro94's Avatar
nitro94
power steering
MThorns
May 18, 2012 04:06 PM
danb303
15
Dec 24, 2008 10:16 PM
hippykiller56f100
26
Feb 20, 2008 05:18 PM
jonws77
1983 - 2012 Ranger & B-Series
Dec 18, 2003 09:27 PM
aj5601
1978 - 1996 Big Bronco
Sep 18, 2002 12:05 PM
