1978 - 1996 Big Bronco
Needhelp with headers
Old Apr 25, 2005 | 05:52 PM
Fordbyford's Avatar
Fordbyford
Question Needhelp with headers
I had bought a pair of Flowtech headers and I want to put them in now that I have more time but I have a 1996 Ford bronco 351L Auto trans and the thing is I cant get in from the toip to the Exhaust mainfolds on the passangerside and if these headers dont fit I can return them as long as there not scratched up so I was thinking to remove the alt to get to the mainfold but has anyone found an easier way of getting shorty headers on with out damaging them if so please repost thank you
Old Apr 25, 2005 | 06:12 PM
greystreak92's Avatar
greystreak92
Haven't seen the Flowtech design but the Bassani shorty will slip in from the top with the purge cannister removed. You have to take some extra time to get the tubing from the smog pump removed as well. When removing the manifold, its easier to just let it drop out the bottom.
Old Apr 26, 2005 | 09:39 AM
Kemicalburns's Avatar
Kemicalburns
some have removed the inside fenderwell to get access to that side of the motor.
Old Apr 26, 2005 | 11:54 AM
HMA-169's Avatar
HMA-169
Are the flowtech headers ceramic coated? How much are they? Let me know how well the fit and if you think they helped. Thanks.
cds
Old Apr 26, 2005 | 03:50 PM
Fordbyford's Avatar
Fordbyford
I'm gonna puttin them in a few from Work sucks but they cost me round 350-375 and yes they are powdercoated once I get it all done iwill post up the info you are seeking
Old Apr 26, 2005 | 11:40 PM
broncobillybob's Avatar
broncobillybob
Originally Posted by greystreak92
You have to take some extra time to get the tubing from the smog pump removed as well. .
Yes, I broke my EGR pipe getting that sucker out, 56.xx from dealer b/c Junkyard only had 5.0 broncos...and the pipes are different. I took the wheel well out for both sides to install. (I have heddmans. 351W)
Old Jul 4, 2005 | 11:01 PM
Fordbyford's Avatar
Fordbyford
Hey BroncoBillyBob whwhen you said you had broke the EGR valve was that the pipe that screws into the header or is the part on top of the pipe cause I finally got them in and I noticed when I took out the exhaust manifold that the EGR pipe had some cracks in the welding please post back
Old Jul 5, 2005 | 09:04 AM
Kemicalburns
just replace the pipe. other wise it will leak and not function properly
Old Jul 5, 2005 | 10:34 AM
Fordbyford's Avatar
Fordbyford
I am so fuggin pissed right nowjust went down to FORD bought a new EGR pipe took it home and then rlized it didnt have the vacuum hoses on it to the EGR valve and that that bolt leading to the EGR valve was to small to even fit over the threads I called ford back up they said theres nothing else that they could do unless I dig some money out of my pocket so they can fit it on for 100 dollars a hour and take another fuggin week I am so god dman pissed right now I'm never buying a ford again I'm sorry I respect the cars and trucks but the Crew is nothing but a bunch of **** sucking mother fuggers I really want to go down there and shove the pipe up there *** to let them know how it feels to be screwed royally over and over again
Old Jul 5, 2005 | 11:27 AM
Kemicalburns
the pipe should connect from the exhaust manifold directly to the underside of the EGR valve. so what part is not connecting correctly?
Old Jul 5, 2005 | 12:02 PM
Fordbyford's Avatar
Fordbyford
The part that goes onto the exhaust manifold fits like a charm but on the underside of the EGR is were Im having the problem I going to see if theres a part at home depot that converts a big thread to fit with a small bolt I didnt mean to go off like that about ford "vechiles" but I still hate there engineers by the way what does the EGR do for me and my truck???
Old Jul 5, 2005 | 12:09 PM
Kemicalburns
im wondering if that egr is off a different motor. for instance a 302 egr is gonna be different then one for a 5.8
Old Jul 5, 2005 | 02:54 PM
Fordbyford's Avatar
Fordbyford
Thats whats I thought till I called him back and asked him to check the information to see if it was right sure enough it wasI tried looking for a coupling to convert thesizes but no luck and get this I went to home depot cause I figured they have something in the plumbing section they did but it was 1 or 2 sizes tro small I asked one of the guys there if they had anything bigger and if I wasnt seeing it and he said nope but you could try this and he brings me to the PVC section and gives me apiece of PVC and said that it should do the trick I looked at him with a blank stare laughed and asked him if he was kidding? Nope it should do the trick so I just turned around and left then got stopped at the door and was asked if I paid for what I had in my hand And I replied with I asked him how much they usally charge for an EGR valve and an EGR pipe and left
Old Jul 5, 2005 | 03:02 PM
Kemicalburns
why dont you go to a wrecking yard or go to a different dealer. maybe that dealer is a jackass
Old Jul 5, 2005 | 05:15 PM
wozxxx86's Avatar
wozxxx86
ive only heard about putting headers in from the bottom.. and ive done it and had no problems whatsoever
rsh27921
13
Jan 8, 2013 03:49 PM
juni88126
Nov 8, 2010 06:56 AM
speed
13
Jun 2, 2006 06:54 PM
samckernan
Jan 17, 2004 11:07 PM
jason86
Jan 24, 2002 08:32 PM
