Tire Size Help
Old Apr 25, 2005 | 05:15 PM
jaytee04's Avatar
jaytee04
Question Tire Size Help
Just put some 285/70/17 tires on my truck about 2 months ago and they are nice but not big enough. I have a 2004 F150 Fx4 with the 2.5 in daystar level kit. Question is will a 315/70/17 fit on my truck? The specs at BFG say that the tire is a 34.5 in tire. Thanks for everyones help...
Old Apr 25, 2005 | 05:48 PM
z3r0's Avatar
z3r0
you would have some wheel rub and definatly wouldnt be advisable to wheel it
Old Apr 25, 2005 | 07:55 PM
judithgap's Avatar
judithgap
Tire Size
I have the same Daystar leveling kit on my 04 Lariate Supercab 4x4. Just had 305/70/17 Wrangler MT/R's mounted on Ealgle 187 17x9 today. Had to do a little trimming to the back of the fender well and the stock running boards and it is still close for comfort. Looks Great though. I would be afraid of the 315's.
Old Apr 27, 2005 | 11:14 PM
RobinBC's Avatar
RobinBC
315's won't fit, I have the same set up as Judithgap. You would need a 4 inch lift to fit them.
Old Apr 28, 2005 | 12:15 AM
industrialjunk's Avatar
industrialjunk
315's fit mine with no lift, check gallery.
Old Apr 28, 2005 | 07:44 AM
z3r0's Avatar
z3r0
That definatly has the "stuffed" look. Looks good but how bad does the front rub when turning?
Old Apr 28, 2005 | 09:47 AM
industrialjunk
It barely rubs at full lock left turn, the tire tread edge just polishes the sway bar. No problems at all offroad.
Old Apr 28, 2005 | 06:35 PM
Bdyzr1's Avatar
Bdyzr1
WHY!!!!!!! would you lower a 4x4, I just dont understand!
Old Apr 28, 2005 | 08:33 PM
RobinBC's Avatar
RobinBC
Industrialjunk,
I didn't think they would fit without a lift. It would be even closer fit with a set of mudders on there for sure. I know my tires polished the arms without the leveling kit.
Old Apr 28, 2005 | 10:45 PM
industrialjunk
Originally Posted by RobinBC
Industrialjunk,
Depends on the wheel, I see you have 17/9's mine are 17/7's alot of the aftermarket wheels won't let you fit 315's without a lift.
lneville
Jan 4, 2014 11:19 AM
5.4f250sd
Mar 25, 2011 06:13 AM
Mike-11
Dec 29, 2010 02:30 AM
Hubnut
Feb 23, 2010 10:10 AM
dstone8368
2004 - 2008 F150
Sep 7, 2008 10:18 AM
