Sponsored by: Real Truck
Beware! Ford molded mud flaps
Old Apr 25, 2005 | 01:05 PM
mwpierson's Avatar
mwpierson
Just a word of warning to those who have the genuine Ford molded mud flaps.
A couple of years ago I installed the front and back flaps on my 02 F250. Saturday, I went to take them off so I could install them on my new rig. Wouldn't you know it, I found very bad news.
I expected to see some wear/chaffing up the sides which is easy enough to buff/polish out. What I wasn't expecting was a fair amount of boils in the paint at the lower corner of each wheel well. Those pockets in the mud flap held water and debris long enough to eat through the paint and into the metal. Rust-through was just around the corner.
IF I put them on my new rig, I'm going to tape up the areas where the flap and fender meet with thick foam tape (used by CAP installers as weather stripping). I'm also going to drill a few LARGE holes at the bottom of the flap so that if anything gets in between the foam and the flap, it can be washed out and the water can drain.
Mike
Old Apr 25, 2005 | 01:10 PM
Big Orn's Avatar
Big Orn
Good point, Mike. Thanks for the info.
Old Apr 25, 2005 | 02:25 PM
sandpic's Avatar
sandpic
That happened to an old truck of mine. I left space inbetween the flap and my truck. You can see it if you really look at it but noone notices.
Old Apr 25, 2005 | 02:27 PM
pac50's Avatar
pac50
Never thought of that, thanks for the heads up!
Old Apr 25, 2005 | 02:51 PM
Wrenchtraveller's Avatar
Wrenchtraveller
I guess that is why the Huskey Mud guards I just put on came with this transparent tape to put between the guard and the body. They give good instuctions how to clean the paint and put on the tape. I did it but thought it was overkill but I guess not.
Old Apr 25, 2005 | 11:14 PM
VR666's Avatar
VR666
Same thing appears to have happened to my 99 SD
Old Apr 26, 2005 | 07:49 AM
mikesZ06's Avatar
mikesZ06
I recommend using grease instead of tape. Grease the entire area and screw holes behind the mud guard. You will hot have any problems with rust or bubbling paint.
Chevra
Oct 25, 2016 01:38 PM
FORD-DNA
6.7L Power Stroke Diesel
Jun 10, 2014 08:23 AM
ComputerCowboy
Apr 17, 2012 08:10 AM
snelldawg
Oct 20, 2011 01:24 PM
tspangle84
2009 - 2014 F150
Aug 20, 2011 05:26 AM
