Sponsored by: Real Truck
Difference between chassis cab and regular
Old Apr 25, 2005 | 12:56 PM
Fullcrew7.3's Avatar
Fullcrew7.3
I have a '96 F350 Crew drw. Turns out my truck is a chassis cab. I have a nice Alluminum utility deck on it, but am still looking at the possibility of getting a regular box. How much difference is there between a chassis cab and regular and what differences would those be. I'm assuming wheelbase, but how much? Does anyone know off hand or know where I can find out? If either a longbox or shortbox may work with minimal /or moderate mods, I may still consider it. If so, how much gap between box and cab, or is this space too small for any regular box?
Thanks
Old Apr 25, 2005 | 07:30 PM
Rongold's Avatar
Rongold
Chassis/Cab & Regular Box
If I remember correctly, besides different wheelbases available with a chassis/cab, the frame rails are closer together on a truck ordered with the pickup box delete. I don't know if you can mount a standard pickup box on a chassis/cab without drilling new mounting holes in the floor of the bed.
RON
Old Apr 25, 2005 | 08:57 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
On a regular truck the CA (cab to center of axle) is 56in, on a cab chassis its 60in. The standard truck has a curved frame rail and the cab chassis has a straight rail that is closer together, Ford Chev and Dog all use the same width. Cab chassis also us a rear gas tank not the midship tank. There is a few after market outlets that has boxes that look like the standard box but are longer, Fontaine is one of them.
Denny
Old Apr 26, 2005 | 05:16 AM
m350's Avatar
m350
I think chassi cab frame rails are 34" out to out,,and pickup bed style rails are like 38" out to out, I went through this when I found my 04' F-350, thinking I could just remove the bed and install a flat bed if I decided too,,,,,,I still can but a little more effort and planning is involved .
Old Apr 26, 2005 | 08:30 AM
Fullcrew7.3
Thanks for the info guys. I hadn't thought of the width between the rails. There isn't any diffefence in axle lenth is there. (a regular box would still fit between the rear tires?) I did measure the cab-to-axle length and it was 57 inches. Maybe that is because it's a cewcab? Anyway, thanks again.
Old Apr 26, 2005 | 11:03 AM
ramblincowboy's Avatar
ramblincowboy
The axle on a cab and chassis is narrower than the axle on a truck with a factory pickup bed. I know that a flat bed built to replace a dually bed will have to be 4" or so wider to cover the wheels. I'm pretty sure the inside duals would be closer together than the wheelwells in your case.
reguy
Jan 8, 2017 03:17 AM
johndeerefarmer
2009 - 2014 F150
Sep 5, 2010 07:48 AM
JnastyG
Sep 3, 2010 01:55 AM
tpalm5
Jul 15, 2005 08:43 AM
sp007
Jul 27, 2003 10:22 PM
