Sponsored by: Real Truck
Brake Vibration / Shutter Problem
Old Apr 26, 2005 | 11:41 AM
Big Orn's Avatar
Big Orn
Good to hear, Mark
I had the same problem with my '99. I had no idea that the rotors were so soft and just couldn't believe the pads would make the whole truck shake. So, hardheadedness won and I made the tech (not Ford - but a good shop) face the rotors again. He didn't complain - he was stumped too. After reinstalling the rotors and checking the runout - finding them within tolerance - we installed the pads and the vibration returned. We went through five different brands of pads until we found a good set. It went away and hadn't been back.
Good luck and thanks for the feedback.
Old May 17, 2005 | 04:21 PM
Bar L's Avatar
Bar L
I am having a vibration in my front left that comes and goes I have checked out everything and it seems OK. I do get the pulse from time to time when I step on the brakes. Does this sound like the same problem? Will brake pads fix it? I have talked to several guys with the same problem but havnt found a solution. One guy should me his front tire and it was worn bad from his truck vibrating and tie rods etc are all good.
Old May 17, 2005 | 06:10 PM
FortyFords's Avatar
FortyFords
BarL ,I suggest you start a new post.
Then tell us exactly what you have chkd.
trying to run with your problem within another post gets confusing.
Rich
Old Jun 6, 2005 | 09:44 PM
compete's Avatar
compete
hi there. does it make a funny metal sound as if metal to metal was actually grinding and you couldnt almost stop???
Old Jun 7, 2005 | 07:24 AM
FortyFords's Avatar
FortyFords
old post,you need to start a new one.your brakes are toast ! if your hearing metal grinding
Rich
Old Jun 12, 2005 | 05:43 PM
compete's Avatar
compete
hi there. the problem was the brake calipers. they had fixed it this past thursday but it came back again yesterday 6/11/05.
SkySkiJason
Sep 28, 2015 06:31 PM
Rusty_S
General Automotive Discussion
Sep 29, 2010 06:44 PM
wegotjs
Dec 31, 2009 04:02 PM
dfeck
Jan 25, 2006 01:50 PM
mjs
15
Nov 30, 2005 09:26 PM
