Remote start for the '05
Old Apr 25, 2005 | 09:58 AM
bricot's Avatar
bricot
Anyone had good luck yet with a remote starter for the '05? If so what brand?
Apparently the signals are now digital, like the glow plug sensor, etc. I had a DEI on my '97 and it worked great so I put a Dei on this truck and they said since the glow plug sensor now sent a digital signal that they couldn't use the glow plug sensor and had to go to a glow plug timer. It also seems to have a hard time figuring out when the truck is actually started. The starter spins for a second or two and then it stops before the truck actually starts.
Old Apr 25, 2005 | 11:22 AM
glafond's Avatar
glafond
Remote Start
Just had the DEI Viper 791XV installed on my '05.
same issue with the "Wait To Start". Installed the pulse timer
set at 45 seconds. Works just fine. did have to increase the
crank time though - this truck doesn't start as consistantly as my '96 7.3 psd.
Get yourself the "Bitwriter" programmer, and you can
play with all these parameters. Cranktime, Tach Sense, Volt Sense, etc.
it's about 100$ online.
Old Apr 25, 2005 | 12:17 PM
hazard's Avatar
hazard
I had a python 881 XP which I think is close to yours. Was going to go for the ford gold for warranty reasons, but had a Ford authorized electronic shop install mine.
Its my understanding that there are 3 ways to do autostart.
1) Timed. Crank for some time seconds. Can be programmed to one of several values.
2) RPM. When the RPM is at a certain level.
3) Voltage. When the voltage level reaches a certain peak.
My guess is that a lot of places may not even tap into the RPM or Voltage stuff and just give you a timed start. Which may change in the winter when you need it most.
The bitwriter, may be a good idea. I know you can program these things using the valet switch. They did not give me the programming guide. But I found one on line.
Glafond, how does the bitwriter connect? Do you have have tot have access to the "brain" of the thing?
Old Apr 25, 2005 | 12:24 PM
glafond's Avatar
glafond
Bitwriter
(Hazard) - the Bitwriter looks alot like the diablo predator, or superchips tuner
programmers. They come with the cable to connect directly to the
comm port on the remote start/alarm unit.
For another 10 bucks you can get an extension cable to permanently mount the comm port like the diagnostics port for the tuners.
Old Apr 25, 2005 | 12:38 PM
bricot's Avatar
bricot
The installer tried increasing the RPM (Tach wire) but when you run it up very much, after starting the unit shuts the motor down with a No RPM diagnostic code.
So this is just an easier way to adjust then using the valet switch ?
It kinda sucks, my '97 started EVERY time ...
I wonder what the voltage adjustment is reading...
Old Apr 25, 2005 | 02:24 PM
roabdog's Avatar
roabdog
I had bought a Bull Dog remote starter for my 03 PSD and I could never get that thing to work correctly. I could not find the tack sense wire. It would start up but shut off in a second. I checked out the Ford ones and I think I will go with that one for my 05. At least I know it will work. And it is worth the extra money for something that works. Just my 2 Cents.
Old Apr 25, 2005 | 03:10 PM
bricot's Avatar
bricot
Is the Ford Gold a dealer only option? or can you get them somewhere else?
Old Apr 25, 2005 | 03:35 PM
hazard's Avatar
hazard
Search for my post, "dealer blows me off". Yes its a dealer thing, but lots do not want to touch the darn thing.
Old Apr 25, 2005 | 06:23 PM
MRKnight's Avatar
MRKnight
Asked the same thing not too long ago, you'll find additional answers to this one here. Myself I went for a Clifford system.
https://www.ford-trucks.com/forums/s...d.php?t=351571
Old Apr 25, 2005 | 06:44 PM
2005F250's Avatar
2005F250
auto start
i have the 05 psd and i got the automate remote start installed at the dealership where i bought the truck. its set up the following:
*glow plugs: on a 30 sec. timer after i activate the system.
*crank time: i changed in to six sec. of crank time, but when it starts before the six sec. it sends the rpm signal back to system to stop cranking.
its also good because it has the turbo timer that i set for 5 min so i could allow cool down after those extended trips. the system is warrantied for 3 yrs. or 36,000 miles. i believe total cost was $400.00 with installation and diesel "wait to start" timer. hope this helps.
Old Apr 25, 2005 | 07:45 PM
firesoutmatt's Avatar
firesoutmatt
remote start
Just got mine back from a electronic shop and works great. He did say something about the digtial glowplug was giving him fits but he got it going. Seems the 05's the glowplugs use an oil temp sensor and brometic sensor to tell the glowplugs how long to stay on and all is controled by the PCM.I don't know how he did it but it works fine.
Old Apr 25, 2005 | 08:02 PM
EnviroCon's Avatar
EnviroCon
Ford had/has a Broadcast Message out about problems with the Tach signal on the 6.0's and remote start. If you want to use the tach signal to let the remote start know your truck has started but it's too weak you can buy a Tach Signal Booster, Ford P/N 102818-2.
firesoutmatt- All 6.0's use those sensors for the glow plugs. If your installer really did use that system instead of the timer for wait-to-start he probably tied into the GPCM. There is a green/white wire in the green plug that is the control signal from the PCM to the GPCM telling it to activate. If he did it a different way I'd be curious to know what wire he was able to use.
Old Apr 26, 2005 | 05:24 AM
glafond's Avatar
glafond
Had to use the volt sense for mine too. The tach signal was too weak.
One thing I don't like is that with the Headlights in Auto, the Lights come on
while the truck is idling. My neighbors aren't going to like that. Has anybody disabled the autolamp feature with the parking brake engaged?
Old Apr 26, 2005 | 01:37 PM
dsweger's Avatar
dsweger
Hi Guys,
I have a Crimestopper RS-900 two-way system installed in my '04 PSD. I used 10 second fixed delay after spending hours researching the glowplug/wait to start issue. (Even at temps below 0 I never saw the wait to start light on for more than about 8 seconds.) I decided under the circumstances, that there was no practical way to use the wait to start circuit. Keep in mind that the glow plugs can remain "on" for some time after the wait to start light has gone out, and even after the engine has started, according to the 6.0 bible.
The Crimestopper has a "tach programming" mode which allows it to search for and self adjust to the vehicle tach signals. Until I figured out how to do that procedure, I had erratic success with the remote starts. After doing the tach programming, it has worked flawlessly cranking the starter for as long as needed to start.
The Turbo timer is selectable in 1 minute increments up to 5 minutes when you turn the key off, and you can also use the "quick stop" feature which will let it run up to 24 minutes, like when you stop for a cup of coffee....
fireoutmatt, I would also be interested to hear what your installer did to use the wait to start feature.
Old Apr 26, 2005 | 03:05 PM
bricot's Avatar
bricot
Tried using the tach sensor side of the programming but when you ran it up very much, after starting it would shut off sensing no/low rpms.
If the Ford Silver/Gold has figured it out without having to go through all this, it may be the way to go.
