headers
Old Aug 27, 2000 | 02:42 AM
geoford's Avatar
geoford
headers
I noticed that most header manufacters skip 1986 f150 302 does anyone know why? will mustang headers fit?
Old Aug 27, 2000 | 08:37 PM
hotrodford_88's Avatar
hotrodford_88
headers
Mustang headers will work, BUT you will have to have the exhaust pipes to the cats refabricated by a muffler shop.
My advice, Call Summit Racing, their shorty truck headers is what I used on my 88 F-150. They run about $160.00 Which isn't bad.
These headers should fit the 86 as well, I don't see why they wouldn't.
Hope this helps
Old Aug 27, 2000 | 09:18 PM
79supercab4x4's Avatar
79supercab4x4
headers
What kind of headers are you looking for exactly? its true theres not a whole lot of options out there but i know for sure you can get some. go to any large local auto parts store and you can usually find two sets (most of the time the average or the quailty coating of the same style) that can be ordered in within a few days. i just helped a freind put a set on his 86. he got longtube headers for just over 100 bucks at an atuo parts store. the only thing...the rest of the exhaust will need modification. my friend ended up taking it into the shop to just have something fabricated. they ended up even needing to cut one of the headers short to keep the tubes from hitting the tranny linkage. basically just check an auto parts store, they usually have stuff that they can order in and if you dont mind getting a full exhaust job while youre at it, then that would work. i dont know whether or not mustang headers would work, im sure it all depends on what you get...theyre all different. the thing is though, that set that was "made" for my friends truck took ten hours to put in, so expect trouble if you end up trying to put in a set made for a mustang. good luck
Old Aug 28, 2000 | 06:58 AM
slikness's Avatar
slikness
headers
For the best fit headers and high quality, find someone who deals with Doug Thorley headers. They fit perfect. You even have enough room to replace your starter without loosening your headers. They will cost in the $350 range (uncoated) but they work terrific. Also, use good quality gaskets or they will burn out. Doug Thorley has a thick, black gasket, ROL makes one of the best gaskets on the market, or if you must use one from your local auto parts store, then put two gaskets on each side.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Aug 28, 2000 | 07:25 AM
slikness's Avatar
slikness
headers
mooray
Exhaust Systems
Aug 29, 2010 02:04 PM
Hausladen
Exhaust Systems
May 4, 2004 08:03 PM
Jan 15, 2003 10:53 PM
gtex
Dec 26, 2002 12:20 AM
Nathan
Exhaust Systems
May 19, 2000 09:03 PM
