injectors
Old Apr 24, 2005 | 05:25 PM
bluegrasslives's Avatar
bluegrasslives
injectors
Hi.
Is replacing injectors a big job, i havent worked on a diesel engine other than change filters and oil and brakes.What does it consist of?Is there any timing involved? First time Diesel owner. 6.9 Ford250 any help is appreciated. Thanks
Old Apr 25, 2005 | 06:02 AM
bilder12's Avatar
bilder12
pretty easy. loosen injection line from top of injector, move line carefully out the way, use socket to remove injector - make sure the crush washer comes out of the bore on end of injector and dont get dirt inside hole while doing so. reinstall new injector with crush washer and tighten to 35 lbs/ft, tighten fuel line and go. Just move the line enough to get socket on injector.
ford1341
Mar 20, 2014 06:41 AM
catman52987
Jan 29, 2012 10:37 PM
heath91
Oct 18, 2010 08:09 AM
74baja
Jan 9, 2009 08:19 PM
Katmandu
Nov 29, 2005 08:07 PM
