Well people, if you thought you were the biggest moron in the world then today is a good day for you cause im claiming that title for now. I was bleeding my brakes as my dad was grilling outside. It was the perfect day for the classic american cookout of hamburgers and hotdogs and of course i was starving and the food was taunting me. So what did i do? The same thing most guys would do. I forgot about my tools and ate all that i could. Then what did i do? Well i layed down watched tv and fell asleep. When i woke up i completely forgot about my tools. The next day i go outside and see my craftsman tools (the best tools i got) laying on the ground soaking in water. The only thing that didnt get wet was luckily my MVP of my tools the 3/8" ratchet. that was sitting on my truck seat. what do i do now?
WD-40. The stuff is great for it's intended use, nothing better. WD=Water Displacement. Sjpray the tools and watch the WD-40 chase the water off. Then wipe down with a clean towel. If they got any surface rust on them rub the rust off with some more WD-40 and wipe them down with a rag with good paste wax on it. BTW BTDT.
No No. They are all wrong. The tools are ruined including the ratchet. Put them in a box and send them to me to properly dispose of them, and go buy new ones.
The tools are ruined!! Take them back to Sears, make a claim on the lifetime warranty, and get a brand new set. A good mechanic only uses shiny tools.
PS. If the tools don't look bad enuf, dip them in salt water for a few days, then you are sure to get a new set from Sears.
My father-in-law, had a socket with a couple of damaged teeth, and the clerk at Sears was giving him some crap about returning it. He took it over to the vise display, clamped it down tight, took a hammer off the shelf, and smashed it up. Clerk didn't give him any more problem.
I was working on our dock and a huge wave splashed into my toolbox, I took everything out, wiped them down and let em dry in the sun, no rust to this day
I live in FL. I keep WD40 on my tools just as a preventive, especially unplated tools such as taps, dies, reamers etc. Things here will rust and you looking at them due to the moisture in the air in June, July and August!!!
rdnkjeeper is correct. Some ATF (doesn't matter which one) will de-rust just about anything. Soak your ratchet in ATF for a while and then wipe/blow it off/out.
