Limited Slip Axle Preload Spring
Old Apr 23, 2005 | 05:17 PM
jwxb41b's Avatar
jwxb41b
Can anyone tell me how to remove the s-shaped pre-load spring from a Traction Lock 8.8 in rear axle? Goes on an '84 Bronco. All I need to do is replace a wheel bearing and seal, but can't remove the axle shaft with the spring in the way. And I can't get the spring over the ends of the axle shafts to push it out. Thanks!
Old Apr 23, 2005 | 07:56 PM
kennethl6's Avatar
kennethl6
The S spring stays where it is. Remove the spider pin bolt and slide the cross pin out. With the wheels and drums off, push the axles in which will clear the c clips from the side gears. Push the c clips out between the S spring and remove axle.
Old Apr 23, 2005 | 08:05 PM
jwxb41b's Avatar
jwxb41b
OK, will give it a try. Thanks!
belshe92
22
Dec 1, 2016 08:18 PM
kas83
Modular V10 (6.8l)
Mar 24, 2013 04:47 PM
VegasFordSD
Apr 25, 2012 02:04 PM
daningraham
Sep 4, 2011 01:46 PM
4x4 Bart
May 28, 2009 05:26 PM
