check engine light, but no code!!!
Old Apr 23, 2005 | 04:28 PM
Budkole's Avatar
Budkole
2 days ago my check engine light came on while driving but went back off while still driving. The engine lost almost all of its power till i hit the gas. Today i was able to get the codes run. All the thing said was "passed"
-no codes
what gives?
95 f350 psd, no chips, straight piped.
btw, i just got it straight piped three days ago, i wonder if that is affecting something
Old Apr 23, 2005 | 09:59 PM
1997F-350's Avatar
1997F-350
probably not a good code reader. what i mean is not just any old obd2 scanner will work on our trucks. actron 9140 works and there are also some coputer based ones that work also. go to a few parts stores and ask to use there scanner. keep going to different places until you find one that works.
Old Apr 23, 2005 | 10:06 PM
barebackjake's Avatar
barebackjake
did the tach drop all the way down or do abnormal things when it did this...thats what my 94 did when the CPS went out.
Old Apr 24, 2005 | 07:45 AM
Budkole's Avatar
Budkole
yes the tach did drop, but when i put my foot on the gas it moved up.
Old Apr 24, 2005 | 09:40 AM
barebackjake
hmmm got me stumped on this one, seems like it defueled over something. seems like it lost the injection pressure sensor for a second threw a CEL and the signal came back and all was good.
with the light coming on and going back off without turning the ignition off and back on i dont think its gonna store the code.
i would check your connections under the hood, clean battery terminals, check your ipr and ips connections and your valve cover connections, seems like an intermitten electrical issue to me.
Old Apr 24, 2005 | 09:47 AM
Budkole's Avatar
Budkole
thanks for the info, but im kinda new to diesels so what and where are the ipr, ips and valve cover connections?
BigBodySage
Jul 11, 2013 09:51 PM
Saxon
Sep 5, 2012 05:38 PM
Bsentman888
Jan 21, 2012 11:20 PM
richis69mach
1997 - 2003 F150
Apr 20, 2010 11:00 PM
justinthompson10
Jan 14, 2007 03:21 PM
