OBS Fuel System Questions
So, I'm getting parts together to build a fuel system. I was going to do the standard regulated return that most folks do. Then I started learning about aerated fuel and the damage it can cause to injectors. So I learned how air separators work, (the patents are out there and explain). It's actually fairly simple, but it requires moving quite a bit of fuel. Which leads me to the question, has anyone kept both tanks in an OBS and gone to larger fuel lines? My thoughts on this are to get a second switching valve and plumb them in parallel for both tanks, or setup a transfer pump and only actually feed from one tank.
There is a moderator on another form who says the stock 3/8" line is not large enough for 238/80s but doesn't really support his assertion. Is that true? My FPR has AN10 inlet and outlet, and AN6 return. I wouldn't mind running larger lines, I just need to figure out how to keep using both tanks.
I know I could switch to a larger single tank, but I want to keep my spare tire and both tanks.
Thanks for any help folks!
Anyone know how to calculate minimum and maximum fuel consumption for a given injector. I've heard 238cc is actually 238cc per minute, which times eight would be about 1,900cc per minute. Is that right?
To my knowledge, the fuel sloshing in the tank alone is enough to introduce air. Pressurizing air to ~20k psi and sending it through the small injector holes erodes the holes. I'm going to do this primarily as protection for my injectors. When I get it all sorted I'll share some videos. Sadly work has kept pushing this project back.
Jonnys.1991
04-02-2015 07:49 AM
MONAVIERONJON
06-19-2013 09:26 AM
karatedavid
06-27-2010 12:40 AM
Centroplex
06-07-2007 07:41 AM
gamehunter
07-19-2002 08:19 PM
