Bronco II Ford Bronco II
remove radius arm bushings .
Old Apr 22, 2005 | 11:12 AM
Monty06's Avatar
Monty06
Question remove radius arm bushings .
here we go again i lost my radius arm bushings today just gone so i decided to buy some james duff stuff . so i got their bushings .
now how hard is it to take out my current bushings and place in those .
what tools would i need never done this before. i went my shop where they have done things on my truck that i can't do at home . and they told me $150.00 to replace both is that to much? just labor
help is needed guys thanks in advance.
Old Apr 22, 2005 | 01:44 PM
Help I M Stuck's Avatar
Help I M Stuck
considering the stock bushing is only $15 each..
You will need a 1 1/8 socket and open end wrench to get the big bolt off of the bottom of the front axle that goes up into the spring..sway bar bolts get disconnected too..then the bolt on the rear of the radius arm.
It's actually not that hard to do yourself..just takes about an hour to do..well it took me an hour to do since i install suspension lifts and such all the time..Good Luck!
Old May 2, 2005 | 08:33 PM
peck87's Avatar
peck87
i dont know about you guys, but i would pay more than that to have someone else to replace mine. i decided to replace mine and ordered them from james duff. the duff kit is only the radius arm bushing. it does not include the spacer. it also does not include the heat shield. to try to shorten it up, i installed the bushings,didn't fit,thanks to fte i found out about the spacer, had to get them from local ford dealer, had to remove and replace with spacer.also i had to hook the rear of my bii to my pickup and the front to a tree with a come-along to pull front axle far enough to get radius rods out of the hole. But GOOD LUCK ANYWAY!!!!
Old May 2, 2005 | 08:35 PM
peck87's Avatar
peck87
also when trying to pull the radius arm down with a cheater bar i kind of knocked myself out when the bar slipped and hit me on top of my head SO BE CAREFUL!!! GOOD LUCK!!!
Old May 2, 2005 | 10:11 PM
mrshorty's Avatar
mrshorty
I've always drilled out the rivets on the radius arm bracket (the bracket that the radius arm bushings sit in) and removed the bracket. The first time around, it's a pain, but once the rivets are out, it's fairly straightforward.
Old May 3, 2005 | 12:08 AM
RomerB2's Avatar
RomerB2
Monty - Did you ever get them in?
Old May 3, 2005 | 03:54 PM
Monty06's Avatar
Monty06
i got them in . wasn't that hard to do either took me about 2hours i also did steering and swar bar bushings
Old May 8, 2005 | 02:49 AM
turborich's Avatar
turborich
i also removed the rivets securing the crossmember. i replaced the rivets with stong grade 8 bolts. next time you need to replace the bushings it will be very simple. it should have been bolted in from the factory.
Old May 8, 2005 | 09:52 PM
plilikoi's Avatar
plilikoi
Only an hour each side? Did you drill the rivets out? If so, what size drill bit did you use and how did you even know what size to use?
Thanks for any suggestions,
Richard
Old May 9, 2005 | 01:21 AM
RomerB2's Avatar
RomerB2
When I put on my lift-kit and had to remove the rivets it took me about ~5 minutes per rivet. I used an chisel air tool to get the heads off and then used a center punch and punched them out with a 15 lb hammer. Then some of the holes needed to be enlarged so I used a Dremel tool.. worked like a charm.
reem98
15
Nov 15, 2023 06:08 AM
warren561
Jan 21, 2022 03:12 PM
diamond mike
Oct 2, 2011 10:48 PM
jad
1978 - 1996 Big Bronco
Nov 11, 2002 09:27 AM
