Minimum Idle speed
Old Sep 20, 2000 | 11:51 AM
Guy's Avatar
Guy
Minimum Idle speed
I have read a post on another web site about "minimum idle speed" for our fuel injected trucks. Does anyone know what the prodedure for this is if any? I haven't read of any in the haynes and the dealer sais they have to hook it up to their special equipment to do it.(yeah right)
Thanks
If anyone has been reading my past posts i'm still looking into my idling problem.
'92 F150 XL 4x4, 5.0L AOD, Headers, K&N Air Filter, 3.55 Gears, 31x10.5x15 Tires.
Old Sep 20, 2000 | 04:44 PM
mragglomerator's Avatar
mragglomerator
Minimum Idle speed
I was just wondering how you have your emissions hooked up for your exhaust?
Old Sep 20, 2000 | 11:02 PM
PAUL_2's Avatar
PAUL_2
Minimum Idle speed
Idle speeds are controlled by the computer . The base idle is set from the factory by an screw on the throttle linkage . Are you having a problem with the idle speed ?
Old Sep 21, 2000 | 08:11 PM
Guy's Avatar
Guy
Minimum Idle speed
I've been having an idling problem for quite some time. I figured that the idle a preset value from the computer and that the idle screw has nothing to do with it. I had adjusted the idle screw but set it back to original position. The truck idled too high during initial start. Thanks
Old Sep 23, 2000 | 02:11 PM
cbwarrior's Avatar
cbwarrior
Minimum Idle speed
I've read in I think the Alldata refence material somewhere about disconnecting the iac at operating temp, have timing set at spec, and set the idle around 500 rpm or so. I may not be correct with the numbers, but the process is correct. I know this works on the 80's models, so if it is set up the same in the 90's, it should work. I would just make sure that the engine is idling properly first, so as not to give you more problems in the future.
Old Sep 24, 2000 | 10:45 AM
Motorcraftsman's Avatar
Motorcraftsman
Minimum Idle speed
frambin
59
Jun 15, 2015 08:49 PM
Bobsandog
Jul 19, 2012 04:44 PM
A H DEVELOPMENT
Jan 25, 2010 05:17 PM
sonora pass
1983 - 2012 Ranger & B-Series
Feb 19, 2009 01:09 PM
jhorton
Feb 28, 2008 05:42 PM
