ez lift
Old Apr 21, 2005 | 09:50 PM
kywildcat103's Avatar
kywildcat103
ez lift
which lift is the best to install ez lift or the daystar?and where do i find either one. thanks
Old Apr 22, 2005 | 04:00 AM
keith Ruge's Avatar
keith Ruge
You can get a good deal on Ebay thats were I got mine But I havent installed it yet becouse IM trying to find out WHEN I tow how much is the front gona go up PS I got the Ezlift @ they came with real good directoins looks easy
Old Apr 22, 2005 | 06:55 PM
who243's Avatar
who243
kywildcat103,
I purchased the ez lift yesterday and it will be here Wed.When I get it installed I'll let you know how the install went. The reason I went with the ez lift was because it looks pretty easy to install .
Old Apr 23, 2005 | 08:01 AM
EnergizerBunny69's Avatar
EnergizerBunny69
I was just thinking, I realize that sometimes that can be a dangerous thing, but anyway. You said that you have not installed them yet because you are worried about how much the front will go up when you tow. My ? is; have you thought about installing a set of load leveling air bags on your ride ? And possibly using a lowered hitch. Just wondering.
Old Apr 23, 2005 | 08:40 PM
keith Ruge's Avatar
keith Ruge
No I dont want the front way up in the air over the back, Wright know the front is 5 1/2" the back is 8" 2" lift would be 7 1/2 when I have my boat hooked up It drops 1/2" I think it would be ok but I want to know
Old Apr 24, 2005 | 12:10 AM
EnergizerBunny69
Well it does go w/out saying that if the back drops down, then the front is going to raise up. If it only drops down about 1/2" then the front is going to raise at least 1/2"-2". Maybe a little more or less. I could be a little off on this figure. Again, alot of factors have to be taken into consideration when trying to figure out how much the front will raise when towing or carrying a load. But again, if you are worried about, I would just get some of those load leveling air bag systems that you can install on the rear axle. That way you can adjust the rear as you need it depending on the load that you are towing. Some of the systems that I have seen in the past even have their own air tank systems onboard. Anyway LOL.
Old Apr 24, 2005 | 06:26 AM
keith Ruge's Avatar
keith Ruge
Thanks Ill keep that in mind but with all the threads that I have read about lifting the front up somebody would do some towing would think ,
Old Apr 24, 2005 | 09:08 AM
Ferguson65's Avatar
Ferguson65
Keith, I don't have a leveling kit on my FX4, but I can tell you that when I loaded the bed with firewood, the rear sat just a hair lower than the front. I also had an empty cross bed box in it, taking up space. When I used it with the trailer to move two big, 55' matco toolboxes, loaded at the front of the trailer, it sat level. So in my opinion, yes you will be nose up with the 2.5 kit if you put anything in the bed. I'm going with a 1.5 kit from autospring beings is I use the truck, but mostly just cart myself around with it.
-Scott
Old Apr 25, 2005 | 10:33 AM
bigtexan99's Avatar
bigtexan99
I really like the EZ lift. Installed it about 3 weeks ago and it looks great, truck still rides the same.
