Stalling when accelerating
Old Apr 21, 2005 | 05:19 PM
doctorj's Avatar
doctorj
I'm the new owner of a 1976 F250 with a 460 and a motorcraft 4 barrel carburetor. I've changed the plugs, wires, rotor, air filter and a few other minor things. The main engine trouble I'm having is this, the engine stalls, it doesn't die, when I accelerate quickly. Slow steady acceloration happens without problems, but as soon as I stomp the pedal, she stalls.
I've sprayed some carb cleaner in the top and ran some cleaner through the gas tank. I'm hoping that my carb just needs to be adjusted. I've also tried adjusting what I beleive is an accelorator pump adjustment, but it hasn't helped.
What next? Any other threads I can read?
thanks
Old Apr 21, 2005 | 10:28 PM
LxMan1's Avatar
LxMan1
Which Motorcraft carb do you have? If it is a 4350 series spreadbore, then it could have either a bad accelerator pump diaphram or a bad diaphram in the secondary air flap pull-off. This keeps the secndary air flap from opening too fast and causing a lean-out bog.
Old Apr 22, 2005 | 08:24 AM
doctorj's Avatar
doctorj
I'll find out about the exact number on the carb. How do you fix this? Rebuild the carb?
Old Apr 24, 2005 | 12:06 PM
LxMan1's Avatar
LxMan1
If it is the 4350, you can just replace the secondary air flap vacuum pull-off.
Old Apr 24, 2005 | 12:09 PM
Spaznaut's Avatar
Spaznaut
Could also be the fuel pump.
Cwarstler
Dec 5, 2015 10:15 PM
spltend
Jan 21, 2015 12:21 PM
FarmerBill
May 3, 2011 12:21 AM
kadrocker
Jan 1, 2010 08:26 PM
0351mike
Nov 4, 2009 07:41 AM
