351M Engine Problems
Old Apr 21, 2005 | 02:14 PM
krazyili's Avatar
krazyili
Unhappy 351M Engine Problems
I have a '79 Ford F150 with a 351M engine. I have set the timming according to the book and set the spark plug cables are in order. I replaced the intake manifold gasket and other gaskets that leaked then torqued the bolts down to specs. I had a compression test done on it and it passed. The problem I'm having is when I try to start the truck, it attempts to but it backfires out the carburetor then dies when I let go of the key no matter where i set the distributor. What did I miss?
Old Apr 21, 2005 | 10:00 PM
LxMan1's Avatar
LxMan1
Either a bad ignition switch or a bad ignition module???
Old Apr 22, 2005 | 07:49 AM
LottaRocka's Avatar
LottaRocka
Sounds like you've got the distributor a tooth or two off.
Old Apr 22, 2005 | 09:19 AM
77460f150's Avatar
77460f150
If your dist is not off by a tooth or two as LottaRocka said and your ign switch and ign module are ok as LxMan1 suggested, it just might be the mag pick up in the dist. I had this happen to me a couple of months ago and it was intermittent so it took me a little while to find and confirm it. -Ed
brownf150
Jul 25, 2012 11:30 AM
Jeremy Ruppert
25
Oct 2, 2009 01:00 AM
Pickupmanx2
Nov 11, 2006 09:46 AM
fordman77f1
Jun 8, 2004 02:20 PM
