Source for steel rims
Old Sep 20, 2000 | 04:18 AM
DannyP's Avatar
DannyP
Does anyone know where I could get plain ol' 16"
steel rims with the 5 lug bolt pattern. What is the bolt circle on a F-150 anyway?
Thanx for any help.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, T-18 but looking for a ZF. 3.55's.
Old Sep 20, 2000 | 09:01 AM
RGAZ's Avatar
RGAZ
[font size="1" color="#FF0000"]LAST EDITED ON 20-Sep-00 AT 10:08 AM (EST)[/font][p]www.tirerack.com
or
www.tires.com/sc
Both do mail order. Or you could try Carparts.com.
If I was going to buy cheap rims, I'd just hit the junkyard and get them for $10 each.
Ties.com has white steelies for about $30 each and the size for stock is 15x8 5-139.7mm or 5-5.5 in inches.
Good Luck
Randy
Old Sep 28, 2000 | 03:47 PM
Trail_Rider's Avatar
Trail_Rider
Stock wheels for an F100 or F150 are 15" wheels on a 5x5 1/2 in pattern. You ought to be able to pick them up from just about any junkyard in the $25.00 range.
Trail Rider
Old Sep 28, 2000 | 11:04 PM
dinosaurfan's Avatar
dinosaurfan
Dan- If you really want 16 inch wheels, head for the salvage yard and look at wheels on a half ton dodge from the mid 90's. They have the same 5x5 1/2 pattern as you do and some came with 16's. DF
Old Sep 29, 2000 | 04:27 AM
DannyP's Avatar
DannyP
Thanks for the input guys. My local salvage yards aren't that well stocked with the later models it seems. I finally found some on the net at a yard in Indiana off a 97 Ford F150. Yes, I was wanting the 16's instead of 15's.
DannyP
Old Sep 29, 2000 | 09:56 PM
mrlaserboy's Avatar
mrlaserboy
The '97-up F-150's have different bolt patterns than the older F-150's. They won't work for you. Best bet for cheap 16" steelies would be from American Racing or take a look at some of the 4x4 mag advertisers. You could probably pick up steel wheels at about $60 each.
Dustin Siebert
mrlaserboy(No Email Addresses In Posts!)
Registry: http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=201
Home Page: http://www.fortunecity.com/silverstone/gear/40
'88 Bronco XLT 302EFI/AOD/BW1356/44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56/6" Superlift complete/35's-street/38.5's-trails
2 BIG BRONCOS 4X4 CLUB - GREAT LAKES CHAPTER
Old Sep 30, 2000 | 09:15 PM
DannyP's Avatar
DannyP
> They won't work for
>you. Best bet for
>a look at some of
>each.
>Dustin Siebert
>Registry:
Yep, You are correct, I just wasted my money.
Every time I try to save some money I end up spending 3 times what I would have if I had just bit the bullet and not tried to bargain shop.
I just wish you had responded sooner.
DannyP
Old Sep 30, 2000 | 10:56 PM
PAUL_2's Avatar
PAUL_2
