New 352 owner
Old May 11, 2005 | 04:58 AM
  #46
GolferSA's Avatar
GolferSA
Originally Posted by ARMORER
Anyway, the guy at the muffler shop says "I cant believe that nobody's ever had the manifolds off of that old 390!" I told him it was a 352. He laughed and said that he's been doing this for over 20 years, and it is definitely a 390. Is my engine a 390? What are some visual cues? How do you tell?
Ryan...
Go ask the muffler shop guy how HE knows... could be a learning experience.
Thanks...
Old May 11, 2005 | 10:38 AM
  #47
ARMORER's Avatar
ARMORER
LOL! I don't think he could have told me if I'd asked! He's one wierd dude. Anyway he was wrong. I measured the stroke, and it is a 352! I was kinda happy about that, it just seems more nostalgic somehow. The more I drive it, the more power it seems to have. After sitting all this time, finally the "cobs" are getting blown out of it.
Old May 11, 2005 | 11:26 AM
  #48
rusty70f100's Avatar
rusty70f100
Dont forget to change the oil a few times. Avoid SM rated oil, as it lacks the necessary ZDDP additive, in the necessary quantities, to protect your flat tappet cam. I'd look for a diesel rated oil, preferably in 10w30. Something with the CH-4 and CI-4 ratings.
Old May 11, 2005 | 07:18 PM
  #49
FERacing66's Avatar
FERacing66
Yeppers. The 352 was a hotrod in its day, Ford got 360 horsepower out it, but those ones are rare. Enjoy the galaxie, the dont make like they did then.
Old May 12, 2005 | 09:29 AM
  #50
ARMORER's Avatar
ARMORER
If this engine never had a detergent oil ran in it will switching to one cause problems? I am surprised that 10-30 would be optimal. In an old FE in the summer I would have thought at least 10-40 probably 20-50. That must be too thick?
Old May 12, 2005 | 12:01 PM
  #51
rusty70f100
If it's not making noise, 10w30 is optimal. Remember these engines have large diameter bearings, and dont require heavy oil. If you feel the need to use something heavier then use 15w40, but no heavier. All you do with a heavier oil is make it harder to start, run hotter, and lose power. You'll also make life harder for your oil pump, oil pump drive shaft, distributor gear and cam gear.
The detergent oil will help slowly clean out the engine, it's perfectly safe. What you want to avoid are engine flush products, they can clog things up.
Old May 12, 2005 | 12:21 PM
  #52
ARMORER's Avatar
ARMORER
Roger that
Old May 12, 2005 | 08:43 PM
  #53
FERacing66's Avatar
FERacing66
Before I pulled my 352FE and rebuilt it, I tried some of that engine flush stuff. It did nothing, nadda. That stuff is a scam if you ask me. About the detergent oil, if the motor is gunked up, the only its gonna get clean is a hot tanking.
Old Jun 21, 2005 | 02:18 PM
  #54
ARMORER's Avatar
ARMORER
Hey Guys, I've been gone for a few weeks for some military training(2 week annual training). While I've been gone, the old Galaxie has been getting her body panels straightened and filled. In 1 or 2 days, it will be in primer and ready for a fresh coat of paint. Here's the dilemma, I have no Idea what color to paint it! It is currently white. The body guy says it should stay that way, he thinks it will look nicer. But he will paint it any color I want. My wife wants it to be bright red. Any input on this? I know this is not the right forum, but you have helped me with other things on the Galaxie so I typed it here!-----Ryan -----pic is a visual so that you can imagine the different colors on it.
Old Jun 21, 2005 | 02:27 PM
  #55
bshackelford711's Avatar
bshackelford711
I have a 1964 galaxie 500 thunderbird special that is gold. Now IMHO i think that is a very pretty color. Nothing beats that gold shining in the sun with the top down.
I will try to get a color strip for you to see if you want it. If i can not get it to post it is the original color for the 1964 Galaxie 500 converitble. With the Thunderbird 390 motor that is painted the same color as the car.
Old Jun 21, 2005 | 02:37 PM
  #56
waldersha's Avatar
waldersha
I agree with several that the 352 is an excellent engine. If I am remembering correctly, this is the engine put into the Thunderbirds of the day, so it was used much as a precursor to the muscle cars of later in the 60's. I have had two different F-series pickups with this engine and had no problem with either. They have incredible torque, I have often put my 66 F-250 in the granny gear and let it idle across a hay field while picking up hay. This same pickup routinely ran 16+MPG.
Old Jun 22, 2005 | 08:27 AM
  #57
bshackelford711
keep us posted on the color.
i would like to see a picture after the car is painted
Old Jun 22, 2005 | 08:53 AM
  #58
hiball3985's Avatar
hiball3985
Black comes to mind for me... what color is the interior?
Old Jun 22, 2005 | 09:01 AM
  #59
bshackelford711
I have seen on that was a dark metalic blue
ver very very nice looking ( i like dark metalic bue and black cars and trucks)
Old Jun 22, 2005 | 09:43 AM
  #60
ARMORER's Avatar
ARMORER
It's kind of a aqua green color. I'm changing that, though. the seats are ragged, and they are being re upholstered by a local shop. I'm going with black, because it kind of matches any color I decide on for the exterior.
